brakes locked up
Old Jul 27, 2009 | 05:00 PM
playfulteck's Avatar
New User
Default brakes locked up
Need help,
on a 95 civic i replaced the rear brakes , rotors , and calipers. took for a teat drive and it felt like the emer brake was on. i unhooked the emer brake and it is still looked up in the back.
Old Jul 27, 2009 | 05:03 PM
waaBAAH's Avatar
Default Re: brakes locked up
which tire is locking up?
hydralically speaking...it is impossible for both your rears to lock up.
mechanically speaking...it is possible for both rears to lock up. so how tight are the wheels when you spin them?
Old Jul 27, 2009 | 05:06 PM
New User
right side is very tight very hard to spin, left side still is tight but able to spin.
Old Jul 27, 2009 | 05:50 PM
waaBAAH's Avatar
adjust your right side piston farther out.. was it tight to install whwen you did install it?
from there make sure all your bolts are tight on the brackets. if they are loose the bracket can turn or pivot creating more force required to turn the wheel.. aka locking up feeling.
lube up your slides.
did you clean your rotor with brake clean? if gunk build up from the rotor is on the rotor...it can gunk up those pads and cxreate unnessary friction. take off your pads and lightly sand them down.. dotn put your greesy paws on the pads themselves.
when the wheel feels liek a lock up condition...unscrew the bleeder. if fluid squirts out (not drips) then you might have to replace your brake hose.
swizz977
16
Mar 10, 2014 08:54 PM
born2lose
11
Jun 17, 2012 06:27 PM
skn181
Feb 1, 2007 12:48 PM
realis9
Feb 16, 2006 05:41 PM
JDM TypeR 307
Feb 27, 2004 06:07 PM
