Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
CSX front end conversion on FA5?
Old Jul 27, 2009 | 01:46 PM
jedi_mind's Avatar
Default CSX front end conversion on FA5?
Didn't find anything on this thread, since there's like 2 pages in the whole 2006-present civic forum. Has anyone ever tried to convert their FA5 to Acura's UK CSX frontend to give it that type-r look? what kind of grill would be needed? And also has anyone ever converted their FG with a FA5 front end?
Old Jul 27, 2009 | 01:53 PM
K5^'s Avatar
K5^
Brand New
Default Re: CSX front end conversion on FA5?
There's more than two pages in this forum. You need to change your preferences to load past pages. To answer your question, yes, it has been done several times. To convert the front you will need:
2x headlamps
2x fenders
1x front bumter
1x hood
1x grill
1x radiator shroud
Rear:
2x taillights (outer + inner)
1x Trunk lid
1x rear bumper.
Conversion kits can be found at kingmotorsports.com.
Old Jul 27, 2009 | 02:06 PM
2008fijibluesi's Avatar
Yes...people have done FA5 to CSX front end before. It involves at least (if not limited to) the CSX bumper, grill, headlights, and fenders. I'm not sure if the hood is the same.
The FG to FA5 front end would probably involve more if it would even work. You'd still need the bumper, grill, headlights and fenders. But I think the hood is slightly different too. You also might need little things like the headlight mounts or inner fender wells from the FA5 because they might not be the same. Also, the fender shape might not be the same where it meets the triangle window/door. Remember the FA has a triangle window while the FG doesn't. You'd get it all on and the door might not line up with the fender. IMO a lot of work and money just to make a car look uglier.
Old Jul 27, 2009 | 05:44 PM
jedi_mind's Avatar
hahah thanks for the responses. Anyone know if using the '09 FA grill instead of the CSX grill will fit?
Old Jul 28, 2009 | 05:37 AM
Kidnkorner's Avatar
Are you financial limited?
Old Jul 28, 2009 | 05:40 AM
d.tek's Avatar
that would be so amazing!
racerx510
Honda Civic (2001 - 2005)
Aug 5, 2012 12:33 AM
mauroe
Aug 30, 2011 09:12 AM
EM2K20
Aug 5, 2010 04:35 PM
drummerdude
12
Mar 8, 2010 07:53 PM
Mentalboy7
Apr 1, 2004 08:50 PM
