Fs: apexi rsm, gauges, Ef hasport, alt, ls meshies, ect OH
Old Jul 27, 2009 | 12:36 PM
EtherEG93's Avatar
Default Fs: apexi rsm, gauges, Ef hasport, alt, ls meshies, ect OH
Ls meshies, painted Gold Great condition. Newer front tires were just replaced with 205/50/15s all around.
Need 250$
voltage meter 30$
D series Aluminum Torque mount (cx special, light weight) 10$
obd0 b16 dizzy?
30$
92-95 dx engine harness 60$
uncut/messed with
D series flywheel,
surface is super smooth just slightly glazed 20$
4x100 civic Spare Tire
Never used 10$
OBD0 B18 dizzy
30$
Da t Bracket, (needed for ef/crx b swap)
30$
EF/CRX Hasport mounts
bushings edges are not mint from engine swaps
250$
Grey eg hatch rear seat belts 20$
Also have black coupe rear belts 20$
Apexi Rev speed meter, works fine, Extended harness
you can have the gauge pod for it 90$
Ef B series Driver side motor mount bracket 10$
Da Engine harness Complete uncut, 30$
Great for parts for Ef/crx mpfi conversion, has all the plugs
Obd2 d series alt 30$
Eg 92 93 glovebox Mint shape 20$
Located in Oh and i accept paypal
Old Jul 27, 2009 | 12:37 PM
EtherEG93's Avatar
Default Re: Fs: apexi rsm, gauges, Ef hasport, alt, ls meshies, ect OH
Crx/ EF Parts
One crack..
88-89 tailights, fit 88-91 crxs 30$ all 3
Other parts...
PM6 ecu 40$
Crx/EF DPFI throttle cable 10$
Will work on mpfi, just a little extra cable
Blue 9005 bulbs work fine, replaced with yellow 10$
Ef clutch cable 10$
Ef Si Fuse box, under hood 15$
Efgauge cluster surround (blue) 10$
OBD0 alt 20$
Crx/Ef stock master cyc 15$
Old Jul 27, 2009 | 12:38 PM
EtherEG93's Avatar
EG parts Include...
P07 Ecu 40$
Z6/b7 fuel rail, 10$
Auto Meter Air to Fuel Meter 30$
d or b T bracket? 20$?
eg hazzards
efdefrost all obo$
eg led?
eg sunroof
eg block off
VSS SOLD
b7 intake mani and tb 30$
Rear belts from a 95 coupe black, 20$ all3
Bumpstops? who needs some
Old Jul 27, 2009 | 12:39 PM
EtherEG93's Avatar
Eg parts Continued
D series Exhaust mani gasket
eg mirror plates, 5$
rear sway with hardware, eg, del sol, integra
50$
D series radiator hoses 5$ each
Del sol cluster 30$
Eg cluster 15$
Also
Eg cluster like the one above missing speedo 5$ good for parts
D series auto starter 25$
p06 and pm6 timing belts
d16a6 and d15b7
10$ each, both used for not long at all a few thousand miles
eg srs harness 5$
EtherEG93's Avatar
Eg parts Cont...
[b]
couplers, 2.5 or 3 (ill check) 5$ both
Light weight crank pully from a a6- 10$
Acura da center caps 5$ (two)
This is a Momo steering wheel Hub Kit. It will fit Momo, Sparco, Bride, etc.... steering wheels.
Fits
Application: Momo Part #: 2401
Avanti Avanti II ALL
Buick All Models 1969-2005
Cadillac All Models 1969-2005
Chevrolet All Models (Except Below) 1969-2005
Chevrolet Camaro 1969-2005
Chevrolet Blazer 1980-2005
Chevrolet Blazer S-10 1980-1997
Chevrolet C/K Pickups ALL
Chevrolet Corvette (Deletes the Telescopic Function) 1969-1993
Chevrolet Corvette C5 (Need to shave some of the plastic behind hub) 1997-2004
Chevrolet Suburban ALL
Dodge Viper ALL
Dodge Neon ALL
GMC Jimmy ALL
GMC Yukon ALL
GMC Sonoma 1992+
GMC Suburban ALL
GMC Typhoon ALL
Jeep Cherokee 1983-05
Jeep Renegade Or wrangler ALL
Oldsmobile All Models 1969-2005
Pontiac All Models 1969-2005
25$ for the hub
obd0 dizzy, isnt a ls one, it was held on to a ls head with one bolt cocked? ill get the code 30$
obd0 ls alt 30$
B20 Valve cover, wrinkle black, 20$
Ls flywheel needs resurfaced 10$
OTHER PARTS NO PICS YET
-92-95 black fuse panel cover with fuse sheet $?
-Dc gsr Right front Caliper 10$
-95 coupe black rear seat belts all of them 30$ all $
-cruise control box out of 95 ex 5$
-srs box eg 95ex 10$ with wiring harness (yellow)
-fuel line, for engine bay, 5$
-Eg pass door cover 10$
-Eg pass door speaker cover, blue and black 2 5$ each
other interior pics for egs coming soon
Old Jul 27, 2009 | 12:40 PM
EtherEG93's Avatar
Valve covers 15$ a pop
(Purple one sold)
17/25 5$
Make offer
ZC dohc intake mani spacer, like hondata 20$ a pop
3 d15 timing covers 10$
1 d16y8 timing cover 10$
95ex srs box, have the harness complete with it, 20$ all
Eg radiator fan 5$
Ecus
P75 obd2 Auto
P07 obd1 man
Pm5SOLD
pm6 jdm zc obd0 man
pm9 obd0 man
!!!!Pm offers!!!!!
PAYPAL ACCEPTED
WILL SHIP
LOCATED IN OHIO
Low&slowEfSedan
Jun 1, 2017 07:25 AM
efcivic12
Aug 24, 2006 08:20 PM
ck123
May 14, 2006 09:40 PM
