k20a2 Block, crank, pan, oil pump + a few other things
Old Jul 27, 2009 | 09:40 AM
shad0wslay3r's Avatar
Default k20a2 Block, crank, pan, oil pump + a few other things
So I have to have shoulder surgery, which means I can't work but my rent payment still needs to be sent in every month.
Which also means I have to sell a few things
I have a k20a2 block with crank, main caps, windage tray, oil pump, oil pan, chain for oil pump, the side cover that covers up the oil pump and chains. Also still have all the bolts for everything that was mentioned.
I'd like to get around $225 before shipping for it, but make me an offer. Crank is pristine and ready to go, I have stored it sitting in the block so there will be no 'warpage' issues.
If you want a certain part of this just make an offer and I will probably sell you it, IE you want the oil pump, make an offer.
I'm going to take pics after I eat lunch, and throw some other random **** I want to get rid of.
Call text @ 952-693-6976
-Garrett
Local Pick ups welcome
Any Questions let me know
Ok here are the pictures
Here is what I noticed about it after it sat for 6 months:
-It will need a hone, there is a little surface rust in 2 of the cylinders
-The oilpick up will come with the whole package or oil pump or whatever.
-if you want it seperate make an offer
-I will not be assembling this back into one piece, if you buy the whole thing you will get everything, but not assembled. I had a hard enough time lifting the main girdle.
-if you want to pick it up, perfect. I only have one arm, but most people can lift an entire shortblock by themselves anyways.
-This whole thing is make an offer.. I just need the money bad.
-Any questions let me know
^^^there is some **** in this cylinder.. like oil sludge. nothing that will affect the cylinder wall
^^ same cylinder with sludge in it, view from squirter
^A2 oil pan
^^ windage tray
^^pan and tray
^^side cover, I do not know if that seal is good or not, i would guess no
^^A2 Oil Pump
^^Main Girdle
Old Jul 29, 2009 | 05:39 AM
Default Re: k20a2 Block, crank, pan, oil pump + a few other things
up
Old Jul 31, 2009 | 09:05 AM
sold
benin360
Nov 22, 2011 03:12 AM
ulemu
Texas -OK -LA (Sales)
Jan 6, 2006 07:47 PM
sleepyhatch00
Sep 2, 2005 01:35 PM
onetwothree
Mar 30, 2003 03:00 PM
