What kind of spark plugs are you guys running?
Old Aug 23, 2002 | 04:53 PM
Tunnel Vision's Avatar
Default What kind of spark plugs are you guys running?
I am running skunk 2 computer, skunk 2 cams stage II. What kind of spark plugs do you suggest running. Do the stock platinum plugs run too hot?
Thanks
Old Aug 23, 2002 | 04:55 PM
WannAbe_DC5's Avatar
From: Emerald City, The Great Northwest Evergreen State, some where
Default Re: What kind of spark plugs are you guys running? (Tunnel Vision)
i run stock platinum with a skunk 2 ecu........i have no problems
Old Aug 23, 2002 | 05:15 PM
batibot's Avatar
Default Re: What kind of spark plugs are you guys running? (lsstfighterturbo)
denso iridiums but went back to ngk iridium (much cheaper) works though ....not as much gains as denso though
Old Aug 23, 2002 | 05:33 PM
Eric R's Avatar
Default Re: What kind of spark plugs are you guys running? (batibot)
There's not such a thing like gains with the iridium plugs, at least on the Rs.
Stock plugs do better in our motors
Old Aug 24, 2002 | 05:55 AM
Incognito's Avatar
Default Re: What kind of spark plugs are you guys running? ('01ITR#950)
NGK BKR6E-11 (NGK part number 2756), gapped at .035. They're 1 heat range colder than stock, I think.
Also, I've run the single electrode Bosch platinums.
Old Aug 24, 2002 | 08:42 AM
sgT's Avatar
sgT
Default Re: What kind of spark plugs are you guys running? (Incognito)
.035 seems a little small. I would stick to around stock at .045.
the ones you have there are same heat range as stock
Rhythmsnewsn
Apr 20, 2006 08:36 PM
fast93accord
Jul 4, 2005 07:54 PM
skierGT
Jun 17, 2003 05:06 AM
GRAVEDIGGER
Jun 18, 2002 01:48 PM
maggsgsr
Apr 4, 2002 08:18 AM
