Koni Integra Shocks Work on 89 Civic Si?
Old Jul 26, 2009 | 01:45 PM
SmellsLikeMustand's Avatar
Default Koni Integra Shocks Work on 89 Civic Si?
Hey guys,
Got a quick question, can EG shocks be used on 89 Civic Si? If yes what needs to be modded?
I have some Konic Yellows with ground controls wanted to put them to use came off my old integra which I sold few years back..
Old Jul 26, 2009 | 01:54 PM
jhammond_82's Avatar
Reject Papi
Default Re: Koni Integra Shocks Work on 89 Civic Si?
the rear's will fit no problem. the front you might need the eg front forks. at least on the integra you do. i would assume it would be the same for the ef's.
Old Jul 26, 2009 | 01:59 PM
Anyone with experience in this swap eg/dc koni shocks on 89 civic si?
I don't want to take everything and find out it doesn't work. I know the rears fit but am not sure about front..
Old Jul 26, 2009 | 02:02 PM
Reject Papi
well since the fronts on da's and ef's are interchangeable, why doesn't it make sense? you calling me inexperienced? lol. jk. jk.
Old Jul 26, 2009 | 02:22 PM
mike-y's Avatar
EG/DC Rear shocks will fit on an 89-91 no problem.
EG/DC Front shocks will fit if you swap over the shock forks. But I believe the EG/DC shocks are a bit longer, so you may lose some suspension travel. Getting a pair of grount control top hats would help this though.
btw, I run this setup with revalved DC2 koni yellows on my 89 civic.
Old Jul 26, 2009 | 02:56 PM
sounds good since the shock is taller how does it fit the lower part of the forks? Was it hard to put on the lower 17mm stud and bolt?
Old Jul 26, 2009 | 07:26 PM
mike-y's Avatar
the EF forks are dimensionally the same as the EG/DC, except for the diameter of the mounting hole the shock fits into (EG/DC has a larger hole). It's the shock body itself that is a bit taller if I remember correctly. My particular koni shocks were shortened though, so they end up being the same size.
Old Jul 26, 2009 | 09:00 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Old Jul 29, 2009 | 07:26 PM
so this works without any problems cause I don't want fruit cake wrong information.
Old Jul 29, 2009 | 07:59 PM
tronsteez's Avatar
Yes it does work.
you need to use eg/dc forks in the front, and the shock bodies are taller so you will not be able to "slam" as much.
Old Jul 29, 2009 | 08:18 PM
last time I tired it didn't fit because the fork was to long EG...I think most of you people have not tired it..
Old Jul 29, 2009 | 08:27 PM
tronsteez's Avatar
I have dampers made for 92-95 civic on my 89' sitting in the driveway right now, it works.
Old Jul 29, 2009 | 09:03 PM
knightsef-eg's Avatar
done..... from a 96 integra gs .... works fine , no clue what name coil and sleeve ..
Old Jul 31, 2009 | 06:05 PM
hmm maybe the tokico illumnia shocks are different because I tired the whites it didn't work..
Old Aug 2, 2009 | 12:10 PM
BigRex88's Avatar
what tophats did u use, did u have to take the shim out of the tophat so the dc integra rod would fit thriugh
Old Aug 2, 2009 | 01:17 PM
nope .. i used my civic top hats and didn`t have to remove anything... it was a complete bolt up for me..
Old Aug 9, 2009 | 07:35 AM
BigRex88's Avatar
I tried to use my original tophats but the metal sleeve wasnt big enough for the dc strut to go through. Are u using ef civic tophats
Old Aug 9, 2009 | 09:45 AM
U mean the fork ? that connects to the suspension?
Old Aug 9, 2009 | 10:05 AM
thisiskev's Avatar
you need EG FORKS. the part that is connects the shock to the lower control arm. i have eg coilovers and i had to get EG FORKS for them to fit. They will work.
ibevila
Nov 4, 2011 05:28 PM
Benjy00
Suspension & Brakes
Jan 7, 2009 03:38 AM
sixtodc2
Mar 10, 2007 09:57 PM
agreziv89ef-8
Jun 9, 2004 08:08 AM
agreziv86EAS
Apr 7, 2004 09:57 PM
