Transmission & Drivetrain Gearboxes, Differentials, Clutches
Tranny damage, ran over something now leaks.
Old Jul 26, 2009 | 12:15 PM
alscrx's Avatar
Default Tranny damage, ran over something now leaks.
So i was driving and i hit a raised sewer cap in the city. I tore off a bolt and the casing from under the tranny. I also cracked a stiffener.
The stiffener is a simple remove and replace cause the bolt is still there and holding.
Its the small bolt that ripped off with the casing. Its causing a leak now and i don't know whats the best way to fix it.
Any ideas?
Old Jul 26, 2009 | 09:34 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Tranny damage, ran over something now leaks.
find another tranny
Old Jul 27, 2009 | 06:27 AM
TheAsian's Avatar
You can try three things, two are guarenteed fixes.
1 find someone that can tig weld and if they can tig the crack in the casing you should be good as long as nothing is knocked up inside of the casing. This is assuming their is a crack and its not leaking because of the missing bolt.
2 find a blown trans and swap your internals over reshim the diff.
3 new trans or used trans
Old Jul 27, 2009 | 03:32 PM
alscrx's Avatar
I don't see a crack in the casing. I just see the bolt is torn off.
Old Jul 27, 2009 | 04:03 PM
TheAsian's Avatar
The bolt that broke out of the casing is one of the bell housing bolts that seals the bell housing to the clutch housing. Start looking for a used trans of a blows trans
Old Jul 29, 2009 | 08:29 AM
Gearspeed-Performance's Avatar
Yeah I would look for another trans...try and get one that may be grinding and not one that grenaded(might have case damage internally). Then just swap the cases over.
Old Jul 30, 2009 | 05:04 PM
alscrx's Avatar
Which tranny cases fit the JDM J1 tranny?
Old Oct 19, 2009 | 05:13 PM
alscrx's Avatar
Anyone have a DIY with pics on swapping cases?
My tranny internals are great with 0 gind! I would like to keep my tranny
Old Oct 19, 2009 | 05:28 PM
Aquafina's Avatar
Internal swap is straight foward except for the mainshaft shim. This requires special tools.
Old Oct 19, 2009 | 07:18 PM
ouji's Avatar
if you have time, u can always try and jb weld it.
Old Oct 20, 2009 | 01:53 PM
Aquafina's Avatar
That is a bad idea. Every trans I've had come in with a problem and a repaired case, the problem has always been caused by the case repair.
Old Oct 20, 2009 | 03:38 PM
alscrx's Avatar
Besides, its hard to seal aluminum because its expanding when hot. Contrasts when cold...
If you need special tools to swap the case then i might as well get a used tranny cause a shop is gonna bang me anyways.
Old Oct 20, 2009 | 03:56 PM
Aquafina's Avatar
Don't know what shape its in unless you can drive it before you buy it. There are alternatives to local shops @ their 65-90/hr rate if you can have some downtime.
alscrx
Jul 30, 2009 04:46 PM
DC206R
18
Apr 16, 2009 09:43 AM
ccivic
Welding / Fabrication
Aug 24, 2005 02:03 AM
inscape
Jan 21, 2005 12:27 PM
