turbo cam
Old Jul 26, 2009 | 11:51 AM
j0keefe21's Avatar
Default turbo cam
been researching and was just looking for opinions on camshafts for a 350-400 whp d16z6. also i was wondering whats the largest cam i could run with out having to upgrade the valve train. thanks guys
Old Jul 26, 2009 | 12:33 PM
tercel95's Avatar
Default Re: turbo cam
The average camshaft set that you buy for a Honda is not going to work well on a FI application... Most cams increase overlap which in the case of FI will just blow boost in and out of they cylinders... I don't know of any turbo application cams for the D series off the top of my head... Skunk2 makes turbo cams for the B series...
I imagine any custom cam that will give you any decent gains will require an upgrade of the valvetrain... Only the milder stage 1 cams don't require changing the valvetrain but even then it is a good idea...
Old Jul 26, 2009 | 12:42 PM
90Rexx's Avatar
i believe venom makes a turbo cam for d series
Old Jul 26, 2009 | 01:30 PM
j0keefe21's Avatar
i thought zex cams were good for boost... am i wrong?
crashsvg
Aug 25, 2025 05:09 AM
Only1cam
Apr 29, 2011 09:48 AM
x-s-i-v
Jul 29, 2009 07:06 PM
Ragecloak
Apr 2, 2005 06:33 PM
