Just bought a used D series Si transmission
Ok ill make this quick and short...just bought a used D series Si transmission...what is suggested to be replaced before the install? It has decent miles and besides the axle seals what else should i do? Thanks in advance!
Mainshaft bearing does go out. If you're comfortable taking the trans apart, I'd look at the gears and synchros, also check the filter/magnet in the tranny for any signs of wear.
This is kinda what i was looking for and i also heard...so i have to tear apart is i do mainshaft bearing? does old d series man trans have a filter? Thanks for the reply!
Thanks good lookin out...ISB= Shaft bearing correct? tear down is needed of the trans? Thanks for lookin out and the advice! highly appreciated.....Thansk to all the good response and time taken for this post!
I'm not 100% sure on the d series trannys, but there should be a magnet near the bottom of the trans that collects the metal particles and this can only be accessed by taking the trans apart.
does anyone know if the main shaft bearings are the same in all D series tranny? EX, Si, DX, and CX... I bought a USED Trany which was supposed to be a 97 EX for my civic DX.. and now the main shaft bearings are making noises when the clutch is disenaged/OFF pedal.. i did all the bearing except the mains.. and i just found out its not an 97 tranny its s20/a0000 out of a 92-95 dx or cx.
Aside from seals and throwout bearings, there's nothing I would do. Just throw it in, if you find anything is bad, take it uot and fix or replace it.
Once you take out a tranny, its easier to do a second time. But the effort to crack it open for the first time and replacing everything just isn't worth it for the slight potential of something wrong withourt even testing it.
call standardtransmission.com get a rebuild kit (bearings , seals , synchro sleeves)
181.61 shipped 2 day air.
then go to tranny shop , install for 150-250 depending on their rates.
then have fun with your rebuilt tranny
finally finish putting everything back on friday night replaced both the main bearings.. honda had to speical order the parts.. fill up the MTF until it leak out.. so far NO noise from the transmission on/off padel.. yay! but found out theres a exhaust manifold leak between the Donut plug and the exhaust pipe...
