Full EF/CRX Coilover Setup!
I have a set of Ground Control Coilovers bolted to a set of KYB AGXs that I have removed from my CRX project car! The spring rates were special ordered from Ground Control and are a stiffer spring rate than the standard kit. They are 438 Front and 376. The standard kit is usually 380 Front and 280 Rear. This helps the car over steer a little more without the need to add a big rear sway-bar. The whole kit barely has 6000 miles on it!
$350 shipped for a fully adjustable EF/CRX Suspension set-up
Thanks for looking!
Bump if you can!!!!
Thanks for looking!
Bump if you can!!!!
nihkon
Jul 3, 2007 11:13 AM
paopao
Nov 27, 2005 08:21 PM
408wdy, 89, coilover, coilovers, control, crx, ef, fit, ground, groundcontrol, hondatech, installation, sale, setup, suspension
