HELP: '88 Honda CRX si _______New problem everything PLUGGED in wont start_____HELP
Old Jul 25, 2009 | 12:16 PM
civichb20's Avatar
PM Garage
Icon3 HELP: '88 Honda CRX si _______New problem everything PLUGGED in wont start_____HELP
HELP: '88 Honda CRX si ________New problem everything PLUGED in wont start_____HELP
Specs
TBA: 1988 Honda CRX Si
engine: D16A6 stock SOHC
notes: Car engine is completely stock and wiring system is stock.
NEW PROBLEM:
Now that I am finish with everything and plugged in but wont start.
Description of problem
1. the high beam light on dash is stuck on
2. both turn signal green arrows on dash are on solid
3. When started nothing just cuts out no engine noise or starter and all lights go out.
What I checked
1. Check battery 11v, all fuses, connections, anything noticable, grounds.
2. switched ECU
Need to check
1. Main relay - how do you check the main relay?
2. if starter is getting power when key is turn on so I can chase problem down.
Notes:
Let me know if you guys need to know anything or what should I check or do.
Please help Thanks in advance everyone
Charles
562-219-1144
Old Jul 25, 2009 | 04:14 PM
black0hatch's Avatar
Default Re: HELP: '88 Honda CRX si ________STARTS WHEN BATTERY IS PLUGED IN________________
the big wire on the starter is probably touching the little wire.
Old Jul 25, 2009 | 04:34 PM
AJxr's Avatar
what he said... or your ignition melted inside. ive had this happen on BOTH of my 88-91 hatches. the little ignition subharness that has the rotating switch inside likes to melt.
Old Jul 25, 2009 | 11:08 PM
civichb20's Avatar
PM Garage
thanks guys it worked and should be racing in no time let me know if you need anything in LA
Old Jul 26, 2009 | 05:19 AM
AJxr's Avatar
so what was it? the little ignition subharness in the car or the big starter wire touching the small starter wire?
Old Jul 28, 2009 | 01:05 AM
civichb20's Avatar
PM Garage
Default Re: HELP: '88 Honda CRX si _______New problem everything PLUGGED in wont start_____
new problem help thanks
Old Jul 28, 2009 | 05:13 PM
civichb20's Avatar
PM Garage
ttt
J . K .
Jan 5, 2015 05:30 PM
J . K .
Oct 28, 2014 07:48 PM
civichb20
Aug 4, 2009 07:37 AM
Raysp30
Mar 8, 2009 03:25 PM
Slow as piss
Aug 15, 2006 05:08 AM
