injector resistor box?
Old Jul 25, 2009 | 10:27 AM
SiR eF_4door's Avatar
From: GWiNNETT COuNTY,ATL...THE STREETSz WERE WE BURN SWEETSz
Default injector resistor box?
do i still need a resistor box if i got the harness to go from dpfi to mpfi and obd0 to obd1??? im droppin a z6 in a 90 dx four door
Old Jul 25, 2009 | 10:32 AM
jhammond_82's Avatar
Reject Papi
Default Re: injector resistor box?
what injectors are you using?
Old Jul 25, 2009 | 10:37 AM
stock z6 injectors...the motor is boosted rite now so it has dsm injectors with the resistor box but ima swappin it into my ef without boost so ima be usin the stock z6 injectors but from what ive heard you only need the injector resistor box when goin from dpfi to mpfi but still stayin obd0...is that rite or am i wrong?
Old Jul 25, 2009 | 10:38 AM
Reject Papi
if your going to obd1, you won't need the resistor box. not with stock obd1 injectors.
Old Jul 25, 2009 | 10:39 AM
Reject Papi
just cut the box off, and solder the wires together.
Old Jul 25, 2009 | 10:41 AM
oooh okay preciate it alot
Old Jul 25, 2009 | 10:47 AM
Reject Papi
yup, no problem.
Old Jul 25, 2009 | 10:56 AM
SIred91's Avatar
Rainman
To be VERY clear.......
IF you are using the OBD1 injectors.......NO BOX
IF you will be using OBD0 injectors.........USE BOX
It doesn't matter how the rest of the motor or ECU is wired.
Old Jul 25, 2009 | 10:58 AM
alrite got it preciate it
92 teggy
13
Feb 22, 2010 08:22 PM
Hondamonster
Jul 29, 2007 08:42 PM
2ndGenREX
Jan 26, 2007 10:12 AM
Lissav
Nov 12, 2005 11:52 PM
vtekthis
Dec 20, 2003 01:34 PM
