dual wastegate spring size question
Old Jul 25, 2009 | 10:17 AM
jdm inc's Avatar
Default dual wastegate spring size question
I had a questions on what spring is recommended for a dual 44mm wastegate setup. The turbo i am using is the twinscroll s372 with the hondata s300 boost controller. tried searching but couldnt find anything. Any help is appreciated thanks in advance.
Old Jul 25, 2009 | 10:54 AM
Boner_Ben's Avatar
Default Re: dual wastegate spring size question
What is the lowest amount of boost you wish to run ? That is the answer to your question.
Old Jul 25, 2009 | 11:45 AM
jdm inc's Avatar
isnt the lowest on a twin scroll is around 15?
Old Jul 25, 2009 | 12:50 PM
dart2.2's Avatar
no, i have the s372 and a 10lb spring and dual 44s and hold steady a 10 psi with the boost controller all the way down.
Old Jul 25, 2009 | 01:07 PM
jdm inc's Avatar
will i be fine with the 0.6 bar spring?
Old Jul 25, 2009 | 03:30 PM
96 GSR-T's Avatar
depends on the total amount of boost you want to run and the method of controlling it, are you using Co2?
Old Jul 25, 2009 | 03:32 PM
boosted91crx's Avatar
what ever spring you choose make sure you switch to a JS boost controller for perfect boost control and yes s300 can control the dual stage versions if you dont want to use a switch.
Old Jul 26, 2009 | 12:56 AM
jdm inc's Avatar
no co2 and the method is the s300 hondata with the boost controller.
Old Jul 26, 2009 | 10:52 AM
jdm inc's Avatar
The total amount of boost i will be running is prob gonna be around 35 psi.
Old Jul 26, 2009 | 12:29 PM
96 GSR-T's Avatar
You definately wont even get close to that with 6psi springs w/o Co2, I would think 1 bar springs should get you close......
Old Jul 26, 2009 | 01:17 PM
jdm inc's Avatar
ok thank you. 1bar it is.
Old Jul 26, 2009 | 02:39 PM
jdm inc's Avatar
anyone else have any other suggestions??
Old Jul 26, 2009 | 07:12 PM
jdm inc's Avatar
anyone?
Old Jul 26, 2009 | 07:15 PM
Boner_Ben's Avatar
Why would someone switch from S300 boost by gear to that junk your pedaling?
OP, I'd suggest anything from 10-13 psi depending on what kind of boost you want to run in first gear.
Old Jul 26, 2009 | 07:30 PM
got wide's Avatar
i dont know if you can still find it or not but i had the same question with same gates and same target boost and there was a really informative thread that came out of it with pictures and diagrams explaining how i got my results but i ended up getting over 25 psi from one 3 psi spring in each gate with more testing still to come i think i can go higher and i was able to turn it down to around 5 psi . i was told and argued with that you couldnt get more boost than double what your spring was rated at. i proved this wrong by a lot, its all about how you route the lines and maybe adding a second solenoid. i was pushed hard to buy a co2 kit but i still dont think ill need it to get to 35psi. search around in this forum for the thread i dont remember the name but it was around last fall. unfortunately the thread ended with me having a hurt engine that i have yet to tear down but the info is there!
edit: here i found it for you https://honda-tech.com/forums/forced-induction-16/dual-tial-44mm-wgs-not-opening-help-2426232/ the first page or two is arguing about wg placement which i also proved my case on but theres still good info that could help you out. hope it helps and maybe you can continue the testing!
Old Jul 26, 2009 | 08:16 PM
jdm inc's Avatar
Thanks for all the info guys.
I think i will stick with s300 boost controller
Old Jul 26, 2009 | 08:36 PM
jdm inc's Avatar
what common springs do a lot of people run with the dual wastegate setup?
Old Jul 27, 2009 | 06:49 AM
rip94delsol's Avatar
I have 1bar springs in my sestup and im running the same turbo, this was recommended to me by a well known person on here also!
Old Jul 27, 2009 | 07:55 AM
Bizarre's Avatar
So that technically means you can't run lower then 1bar of boost correct? Do you have trouble putting that power down in first?
Old Jul 27, 2009 | 08:55 AM
jdm inc's Avatar
^^ yea also curious about laying down the power.
Old Jul 27, 2009 | 01:25 PM
96 GSR-T's Avatar
We have FWD cars with huge amounts of power, there is no laying down the power in 1st gear....... I didnt even make 14psi in 1st or 2nd gear I spun so hard on slicks there was no load to build the boost.
With that being said I have 10psi springs in my new Tial 38mm MVS's but I am running AEM and its supposed to have a much better PWM driver that can make 3x to 4x spring pressure according to my tuner.
Old Jul 27, 2009 | 08:38 PM
jdm inc's Avatar
so would i be able to build around 35lbs from a 1bar spring in my 44mm wg?
Old Jul 28, 2009 | 12:46 PM
96 GSR-T's Avatar
I dont know, I think the solenoid frequency is the Smanager software is non-adjustable, which will probably affect the total amount of boost you can make.
Typically you can make 2x spring pressure, sometimes more.
Old Jul 28, 2009 | 05:16 PM
jdm inc's Avatar
I hope it will be fine.
Old Jul 28, 2009 | 05:37 PM
cfwthb_94's Avatar
with a f38mm tial wastegate, red spring (5.8psi) I was able to get 22psi out of it.
