Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast.
Old Aug 23, 2002 | 01:55 PM
ArchAngel Sabastian's Avatar
New User
Default Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast.
I started my car today and the idle seemed a bit high and i just shrugged it off as the warm up idle well all my way to work the idle would not go below a thousand rpms and it fluctuated up and down between 1000-1300 rpms i checked for vac leaks and didnt find any i felt the tops of my plug wires and cly's 2 and 4 had a tap in the top of the wire so i poped the wires off and those plugs were loose as all hell so we went ahead and replaced all the plugs/wires but the bad idle/ exhuast pop is still there, this just started this morning with the bad idle but the plugs might have been lose for a while ill never know.
any ideas of what else to check
no CEL on.
Old Aug 23, 2002 | 02:00 PM
The Acclude's Avatar
Default Re: Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast. (Sabastian)
fast idle thermo valve stuck?
Old Aug 23, 2002 | 02:10 PM
New User
Default Re: Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast. (The Acclude)
checked doesnt seem to be the prob.
[Modified by Sabastian, 6:13 PM 8/23/2002]
Old Aug 23, 2002 | 02:21 PM
Spade's Avatar
Vaccum lines.
Old Aug 23, 2002 | 02:22 PM
New User
Default Re: Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast. (Spade)
any idea where? i cant hear a leak ive check all the ones i removed capped during the intake install there the same as theyve always been.
Old Aug 23, 2002 | 02:31 PM
New User
ive been on here for maybe 15-20 mins and i went back out and looked at the vac lines all look ok, i started the car and it idled perfect for maybe 10 - 15 seconds no popping smooth idle at like 700rpms then after that it jumped back up started doing the same thing....
[Modified by Sabastian, 6:09 PM 8/23/2002]
Old Aug 23, 2002 | 02:38 PM
New User
i took off the intake and theres the two holes on the firewall side of the TB if i put my finger over the bottom one nothing happens and if i put it over the top hole the idle goes down like it might die and the levels off at 500 but the exhuast pop is still there.
ideas? common guys i dunno what else to check..
[Modified by Sabastian, 5:49 PM 8/23/2002]
thinking the pop is a missfire when ever it pops the idle dips down a bit, but its not constant like if you were to remove one plug wire, its random.
[Modified by Sabastian, 6:05 PM 8/23/2002]
Old Aug 23, 2002 | 03:45 PM
New User
anybody got anything? ehh my head hurts.
Old Aug 23, 2002 | 04:32 PM
kcxtremeaccord's Avatar
Mabey you should trade the piece of crap out of my driveway and get a S2K You lazy bastard. Just kidding, anyway I am still thinking on what it is i holla at you.
Old Aug 23, 2002 | 05:09 PM
Default Re: Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast. (ILiveNextToSabastian)
cuz im poor SUCK MY ****
Old Aug 23, 2002 | 05:14 PM
Martaigne's Avatar
Fast idle thermo valve, I believe you're supposed to feel a current through both of those holes inside your throttle body.
Old Aug 23, 2002 | 05:17 PM
New User
Default Re: Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast. (martaigne)
hmm, i two feel inward current on the top most hole and plugging it with my finger drops the rpms too 400 ish but they still flux inbetween 400-600rpms, and plugging the bottom hole does seemingly nothing.
Old Aug 23, 2002 | 05:18 PM
Martaigne's Avatar
You're supposed to feel current on the bottom, I know I do on mine. Most likely the wax plug is stuck or something. I'm not entirely sure how to fix this.
New User
i can replace the whole fast idle valve i suppose but would that cuase the exhuast pop as well? i was leaning toward a fuel/ignition prob becuase of the lose plugs, carbon on plug wire boots, and the excess vapor out of the exhuast.
edit: allthoooough... that might explain why i havent any power loss?
[Modified by Sabastian, 8:20 PM 8/23/2002]
[Modified by Sabastian, 8:23 PM 8/23/2002]
Old Aug 23, 2002 | 05:26 PM
Martaigne's Avatar
Hm, sounds like you might be running rich, too. It sorta sounds like two unrelated problems. I'm not an expert though...
I think exhaust pops are usually caused by small amounts of unburnt fuel igniting in the exhaust.... which would mean you are running rich. Maybe someone else can back me up on this or tell me I'm wrong...
Old Aug 23, 2002 | 05:29 PM
New User
hopefully someone will, how would i be running rich? youd think with I/H/E if anything id run leaner?
Old Aug 24, 2002 | 07:29 AM
New User
ttt
Old Aug 24, 2002 | 09:03 AM
smokin rubber's Avatar
how old is the exhaust, it might be rusting, Mine is doing the same thing.
Old Aug 24, 2002 | 09:43 AM
New User
Default Re: Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast. (smokin rubber)
its brand new.
Old Aug 24, 2002 | 01:01 PM
New User
ok replaced cap/rotor/plugs and still high idleing, adn random pop in exhuast (misfire?)
any idea on what else i should check?
Old Aug 24, 2002 | 03:37 PM
New User
My engine is misfiring at idle, high idle, and i noticed now hella vapor comming out of the exhuast so yah color me confused. oh yeah still no power loss
According to helms that means:
1. Spark plugs worn or not gapped
New bosch +4
2. Fualty Wires
New OEM wires
3. Vacuum Leaks
Checked all lines seemingly no leaks
4. Incorrect Ignition Timming
5. Uneven or low compression
the last two or the only ones i havent looked into
[Modified by Sabastian, 6:43 PM 8/24/2002]
Old Aug 24, 2002 | 06:00 PM
John's Avatar
New User
Chech your idle screw too...
Old Aug 24, 2002 | 08:09 PM
New User
Default Re: Help, Fluctuating Idle, Small Unsteady non rythmic pop in exhuast. (Indecisive DunReit)
will do
Old Aug 25, 2002 | 08:37 AM
New User
started the car this morning and let it warm up and the idle has corrected itself it does the warm up idle and then settles down to 600-700 rpms, but its still missing and i reved it up to about 1500 and i can still hear it missing and at 2000rpms the same. so its missing throught the whole rpm band i just cant hear it at higher revs, there's a good amount of gas/vapor comming out of the exhaust so running rich.
so its out of time? or uneven compression?
haynes list a whole mess of **** to check, i dont have the tools to be doing half of this stuff....
Old Aug 25, 2002 | 08:48 AM
WhoNeedsVtec's Avatar
You didnt advance your timing did u? Also check your compression...that would be a start.
