91 civic
Old Jul 24, 2009 | 11:19 PM
siR-E_978's Avatar
Default 91 civic
windshield wipers do not move at all even wen i flip the switch what can this be?
i checked the fuses
Old Jul 25, 2009 | 01:53 AM
DCRB's Avatar
Default Re: 91 civic
is the motor plugged in?
Old Jul 25, 2009 | 04:23 AM
jhammond_82's Avatar
Reject Papi
or even burned out?
Old Jul 25, 2009 | 08:31 AM
siR-E_978's Avatar
does any1 know how i can access the motor cause if thats the problem i have new ones from another car
Old Jul 25, 2009 | 08:35 AM
OddityDX's Avatar
the motor is between the right front shock tower and the firewall. Its right there in the corner. Did they work before? Have they been taken off recently? If they have been off they may not be tight enough. You may want to see if the nut is tight.
Old Jul 25, 2009 | 08:37 AM
grog's Avatar
take the cowl off. the motor is in the engine bay but to be removed it you need to disconnect to linkage under the cowl.
Old Jul 25, 2009 | 05:05 PM
siR-E_978's Avatar
thanx guys got them working replaced the motor
joescivic91
Mar 26, 2008 11:09 AM
k20o2o4civic
Jan 17, 2007 07:45 PM
bodiez
Jan 6, 2005 05:22 PM
bodiez
Aug 27, 2004 05:34 PM
