Suspension & Brakes Theory, alignment, spring rates....
ABS delete on 92 GS-R. Looking for a brake upgrade. Suggestions?
Old Jul 24, 2009 | 10:30 PM
1992db2's Avatar
Default ABS delete on 92 GS-R. Looking for a brake upgrade. Suggestions?
Hey H-T.....
So i deleted the ABS on my 92 GS-R. And im looking to do upgrade a little bit now that i dont have ABS. I will be getting hawk pads and powerslot rotors.
I was wondering if i can upgrade my booster and cylinder to a JDM ITR master and booster. Will it work?
Old Jul 25, 2009 | 01:06 AM
1992db2's Avatar
Default Re: ABS delete on 92 GS-R. Looking for a brake upgrade. Suggestions?
wow
nobody?
Old Jul 25, 2009 | 06:52 AM
Dogginator's Avatar
Daisy... Daisy...
Sure it will. it simply has a 1" bore? Check your current MC. If it is stamped 1, it is also a 1" bore. You will gain nothing in that case, not that you would gain much over a 15/16" bore MC. Such a swap will also require custom lines.
1992db2
Jul 29, 2009 11:32 PM
devbes
Mar 29, 2007 03:10 PM
92integraVTECgsr
Apr 16, 2006 08:52 AM
manekDC2.
Mar 30, 2006 07:09 PM
