best place to get these parts???
Old Jul 24, 2009 | 01:44 PM
spidy3's Avatar
Default best place to get these parts???
Doing a rebuild on my 95 GSR and have some parts I need/want to replace....
- Coolant hoses (off intake mani)
- Knock sensor
- Distributor cap and rotor
- Drivers side lower motor mount
- Key that the balancer pulley slides on...???..... flat on one top and rest is round (half moon style)
Would I be fine to just get these parts at Autozone/Advanced?
First parts I've needed to buy for teg so wasnt sure if the ones from there are "up to par" and decent quality.
Old Jul 24, 2009 | 06:14 PM
KWayRacing's Avatar
Default Re: best place to get these parts???
oem always fits and quality took you this far(15 year old hoses). The extra money(negligible difference) is a tiny(read very tiny) amonut of a good quality "rebuild" job. I would buy a used OE knock to save a little bit. An aftermarket D mount as I call it is also a spot for potential savings without major quality differences, but the key, cap and rotor, and any coolant hoses, OE is the only way to go. I use NGK/ denso wires/ plugs because they are OE just cheaper from Advanced than from the dealer even at cost.
Old Jul 25, 2009 | 12:22 PM
OH_1fstgsr's Avatar
- Coolant hoses (Samco for the two main, the little short one OEM)
- Knock sensor (Omni Power makes one or OEM)
- Distributor cap and rotor (ONLY OEM, period)
- Drivers side lower motor mount (Get ITR OEM ones, a bit cheaper than GSR and stiffer)
- Key that the balancer pulley slides on...???..... flat on one top and rest is round (half moon style) (OEM)
Would I be fine to just get these parts at Autozone/Advanced? (NO)
chappys4life
Aug 25, 2018 06:10 AM
CD5B2
Apr 5, 2013 08:31 AM
tercelrcr
Mar 29, 2012 01:17 PM
wernhersey
Feb 28, 2008 04:53 PM
