ac not working in town only on freeway
Old Jul 24, 2009 | 01:26 PM
94LS_allmota's Avatar
Default ac not working in town only on freeway
Hey i gots a 96 honda civic with a gsr swap with b series ac compressor and 99-00 si condensor ......but my ac for some reason in town doesnt really work too good........only when i drive on a long road or freeway it works good........what can i start checking 1st to solve my problem...........lmk thanx HT
Old Jul 24, 2009 | 01:46 PM
MONSTERZC's Avatar
Default Re: ac not working in town only on freeway
What i would do first is take the readings from the low and high side. You could be low on freon. You could have a blockage somewhere in the condenser or evap core. A bad expansion valve. Check the condenser fan motor.
Old Jul 24, 2009 | 04:08 PM
fcm's Avatar
fcm
Old Fart
Condenser fan is not turning on, not enough airflow through the condenser at slower speeds. 94
Old Jul 24, 2009 | 05:57 PM
KWayRacing's Avatar
x2. I would first make sure the condenser fan is working when you turn the AC on. Without it, at low speeds or stopped head pressure goes sky high. Even in slow driving around 35-40mph the condenser fan moves faster than windforce can turn it which would give you higher than normal system pressures= less cooling. Other resons are being overcharged/ undercharged/weak compressor but doubtful. Without pressure readings ac diagnosis can only go so far. Without them, you can check fan operation, pay attention to cycle time, adjust the heater cable and thats about it.
Old Jul 24, 2009 | 06:06 PM
Thanxxxxxxx guys ima check it out today......
knotcher
Jun 29, 2015 10:34 AM
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
tronic
Jun 2, 2010 05:27 AM
stockEJ
Aug 6, 2008 06:46 PM
stockEJ
Aug 6, 2008 06:45 PM
