California speedway Friday July 31 Open test day with NASA $149
California speedway Friday July 31 Open test day with NASA $149, if you are not a member yet the membership is $50 and included free 1 year on grassrootmotorsports magazine.
HPDE 1 in full (novice never been on track) HPDE 2,3,4 are open but you need to have track experience.
Here is the info on HPDE program
http://www.nasaproracing.com/hpde/
Of course race car is open test.
here is the link to sign-up
https://www.nasaproracing.com/event/954
Benny
Benny
I was thinking about bringing my car down for a shakedown but electrical deamons are haunting me. Anyone with spark chasing abilities shoot me a PM.
I'd like to get out there.
Benny should have some laying around (obdI b series vtec)
Here is what i have so far. car wont turn over.
Checked the main relay not it...
fuel pump ok ,relay good. No starter solinoid click. (starter replaced twice already)
Clutch interlock switch not connected it has a (push start button) so I need to track down interlock wiring to see if its come undone.. Or rather how would it need to be connected to bypass the switch and let the engine fire?
the clutch switch thing is always conected and disables the car from starting. Once the clutch is depressed it is disconnected and the car can start.
So unplugging it is just like depressing the clutch...
I had that wire just stop working randomly. the connection looked good on both ends but continuity test showed it wasn't working...
Did it work previously? Or did you install the start pannel and stuff stopped working?
no starter panel, just push button, ignition,and fuel toggle switches.
On off switch which i think is a longacre.
Im at a loss now.
BTW this is a D16Z6 engine
Im at a loss now.
Get out the voltmeter...
Check to see if you have + coming into the ing switch, + coming out of the ign switch, +coming into the push to start, +coming out of push to start.
If all of that checks out. Go to the starter. The wire that clicks the starter over is the butt connect one. Push the PTS to ingauge it and see if ur getting +at that.
Wiring isn't that difficult to figure out. Esp if its a power or ground thing. Voltmeter is your friend.
Changed out the Odyssey battery with one in my De La Sol this morning...
I suspect the voltage was a might low after all this mess.
Now I at least get a click on the starter solenoid but no turn over yet.
its getting close.
It could be the wiring from the on/ off switch to the starter??
its getting close.
its getting close.
its getting close.
Check the battery positive too see that you are getting 12volts to it. This might be the cause, if you recently put in a kill switch.
Kill switch has been in there since day one..
I have an experienced honda guru coming by tonight and we'll dig around with the dual voltmeters. hopefully we'll track the beast down and kill it for good.
Thanks for your imput everyone especially Jimmy Joe and Charles its very appreciated.
Problem solved.
Engine ground from the tranny to the chassis.
Its too late to make the trek to Fontana but i still might show up and harass you all.
Thunderhill is coming up and I'll be there all weekend for sure.
Thanks Brian for all your expertise and help.
I owe ya!
I owe ya!
No Problem. I'm glad it was an easy fix.
My first HPDE instructor said I am almost ready for HPDE 2 yeah. I had so much fun it was like drugs although I never taken. See everyone at Buttonwillow. I am also glad you got your hatch fixed Brian sounds like he has skills.
Brian is the man! Glad you have fun. but thats not a CRX??
I am readying for Thunderhill.
Rest be sured I will come down and play with the so cal guys soon.
I had to take the Honda Fit out instead the CRX to many small problems that I needed to work on I wanted to no worry about reliablity problems and just focus on learning hope to see you soon. I am getting ready for Buttonwillow have fun at Thunderhill.
ewaugh
Jun 7, 2007 05:32 AM
Shmeek
19
May 3, 2006 10:55 AM
Back in Black
23
Jul 23, 2002 07:06 AM
