Where the does this Engine Ground route to?
Old Jul 24, 2009 | 08:33 AM
Nisif's Avatar
Default Where the does this Engine Ground route to?
I'm putting a h22a into a 95 Accord. This looks like a typical thermostat ground however it's not within reach. I know a ground is a ground but I'm curious where Honda mounted it. PICS:
This is where I routed it to:
Old Jul 24, 2009 | 09:36 AM
tamadrummer1120's Avatar
Default Re: Where the does this Engine Ground route to?
Pretty sure you can look up the Honda ground locations, so just trace that wire from its source, and then look up where it actually did go.
Old Jul 24, 2009 | 02:01 PM
hon2984's Avatar
If your fuel system doesnt work when it is not grounded, then it should be routed to the thermostat housing area.
I'm almost positive that is where it goes.
Tucked in the back will work just fine though.
Old Jul 27, 2009 | 12:49 AM
Nisif's Avatar
Good point, I'll leave it as is. I'm surprised the Accord wiring harness didn't come close to the stock thermostat grounding location on the H22a. If I have any issues with fuel or the ecu I'll know where to look first. Thx
Old Jul 27, 2009 | 01:29 AM
GhostAccord's Avatar
I'm pretty sure what you have pictured above is the engine harness ground (G101). It is attached to the end of the intake manifold on the F22B1-2. Not the thermostat. You should attach it to the H22 manifold anywhere you can find a spot. It's the same thing as the thermostat ground only they moved it to the manifold on the Accord's
Old Jan 28, 2020 | 10:53 AM
MarkerCD7's Avatar
Did the ground end up working on the back of the block by the oil filter or did you have to relocate it to the intake manny? And did you have any fuel injectors issues when starting your H swapped accord?
Nicholas Bailey
May 13, 2016 05:04 PM
91highryda
Jul 3, 2011 10:47 AM
YoungKadafi
Welding / Fabrication
Apr 16, 2007 10:23 AM
3ni_stylez
Audio / Security / Video
Jul 14, 2006 09:54 AM
hyperB16Turbo
Mar 10, 2005 04:59 PM
