quick painting questions
Old Jul 24, 2009 | 07:47 AM
DulinDragons's Avatar
Default quick painting questions
OK, i read the sticky on top this forum and found most of the info i needed, but still have a few questions. Simple questions.
1.) Air Pressure. Right now i have my gravity fed gun set at 20 psi at the regulator and when i pull the trigger it stays at 19psi. I read on the chart for my paint it asks for 6-9psi from the gun. What does that mean exactly? When i pull the trigger, is it suppose to be at 9psi instead of 20psi? JW
2.) Tach Coat. Does not count as one of the 2-3 coats right?
3.) Flash Time. My paint calls for 5-10min flash, is 15min ok?
Paint Using: Limco Basecoat/Clearcoat from Carquest.
Old Jul 24, 2009 | 11:07 AM
shocker911's Avatar
Default Re: quick painting questions
dont shoot it at 9psi i shoot 20 at the gun 90 at the wall
NO
15 mins might be a lil to long depends on temp. where you are painting
{AJ}
Paint and Body
Mar 20, 2009 03:36 PM
Eyger
Paint and Body
14
Mar 12, 2009 10:15 PM
91(si)hatchey
Paint and Body
19
Dec 25, 2008 05:58 AM
D16SiHatch
Paint and Body
Jul 16, 2007 10:07 AM
