rear disk upgrade wich hose to use???
Old Jul 24, 2009 | 01:26 AM
dacrxguy's Avatar
Default rear disk upgrade wich hose to use???
I have a chance to buy a rear disk upgrade for cheap and was wondering what hose i would need to connect the hard line to the caliper will it be my stock dx one or will i need a da hose. i already have the prop valve and disk and rotors but it will be a shame if i don't have the correct brake line.
ps the rear brake line was cut so i cannto use it a a reference hence why i is asking
Old Jul 24, 2009 | 03:09 AM
jhammond_82's Avatar
Reject Papi
Default Re: rear disk upgrade wich hose to use???
the integra rear brake upgrade is probably the most popular. as far as which brake line to use, i'm not sure. look in the faq to see if someone put an diy in there.
Old Jul 24, 2009 | 07:31 AM
Ldo's Avatar
Ldo
If your stock line is for a drum brake, it will not work as it has different fitting at one end. Use the DA line in your case.
Old Jul 24, 2009 | 08:10 AM
EL Vap133's Avatar
I used 90-91 CRX Si brake lines on my CRX.
Old Jul 24, 2009 | 10:27 AM
GroundZer0 336's Avatar
crx si for sure works, i think the da ones work too. you could probably get some braided lines for about the same price if your buying them new.
Old Jul 24, 2009 | 06:53 PM
dacrxguy's Avatar
thanks guys i will get me a set of new si rex and probaly a set of da ones or dc ones since that is what the rear disk came from
Old Jul 24, 2009 | 07:41 PM
shawn_crx's Avatar
si or da will work... don't for get the bb/mc and the ebrake cable line
Old Jul 24, 2009 | 09:58 PM
dacrxguy's Avatar
gotcha and the prop valve
Antinull
Oct 9, 2011 10:01 AM
Spec Jay
28
Sep 10, 2009 08:49 PM
immajackuup
Jun 27, 2008 07:43 AM
JDM_SOHC
Jul 16, 2007 05:38 PM
EF_ST@TUS
Apr 12, 2006 01:00 PM
