b18c5 sleeve and bore!
Old Jul 23, 2009 | 08:38 PM
JDMx2103's Avatar
Default b18c5 sleeve and bore!
Has anyone ever sleeved a b18c5 block and bored it out to 85mm with pistons that yeild about to 11:5 - 12:5 compression ratio. Is it worth it to bore it out? As in power wise was it worth it? What are some way that i could get more power out of my motor... N/a so no force induction ! Also when a b18c5 motor is bored out to 85mm about how many liters is that? Thanks!
Old Jul 23, 2009 | 09:14 PM
EFsSuck's Avatar
Default Re: b18c5 sleeve and bore!
NA cars are slow...
sounds like you should do LOTS of reading (no posting) in the All Motor forum, and/or have someone build you a motor.
note: i have a NA 220whp/148fttq 84x89mm 2.0l in my R...
Old Jul 23, 2009 | 10:29 PM
wu`'s Avatar
wu`
Go K series!
I was in the same situation about nearly 2 years ago and weighed up the costs and pros and cons of each and then decided that K series would probably be better a choice!
Old Jul 23, 2009 | 10:48 PM
EL TYPE R's Avatar
Boost it, its less expensive and you will have more power withought having to abuse your engine past 85K RPM. Power is what you want right?
Or sell the B18C5 and get a K.
Old Jul 27, 2009 | 09:53 PM
NikeKiid's Avatar
sell your b18c5 for 3k ish and then buy a k20 off password JDM for 3k lol
Aesthetic Gains
Jun 9, 2012 08:49 AM
dragsol
Dec 18, 2009 01:53 AM
fartrice69
Aug 7, 2007 04:00 PM
EtchaSketch
Aug 21, 2005 06:12 PM
AussieK24
80
Oct 21, 2003 05:48 AM
