Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Motor mount troubles.. what to do what to do
Old Jul 23, 2009 | 06:14 PM
85_305's Avatar
Default Motor mount troubles.. what to do what to do
When I did my trans swap, i noticed the front mount was ripped apart (know how it's kinda circular? The rubber or whatever within that circle ripped). And it's annoying as hell because now the motor rocks and **** when turning on/shutting off, and when I have to accelerate rapidly and shift rapidly.
What are my options? I'd rather go aftermarket, and traditionally I use Energy Suspension.. but whats your opinions?
Matt
Old Jul 24, 2009 | 04:56 PM
baron340's Avatar
Default Re: Motor mount troubles.. what to do what to do
ES inserts are all that is really available. But it won't totally fix a torn mount. I do believe there are some solid mounts available but they are hella expensive.
Old Jul 25, 2009 | 05:02 AM
85_305's Avatar
So what should I do? That circular mount in the front is torn in the circle (if that makes sense), and the motor clangs when I give it gas. Which is annoying (only if it's nearly floored though)
Old Jul 25, 2009 | 10:50 AM
toyomatt84's Avatar
Sanji
Remove the mount from the car, and then fill it with some urethane.
http://www.raktron.com/misc/mt.htm
Old Jul 25, 2009 | 01:19 PM
85_305's Avatar
That is certainly a good idea.
There aren't any other aftermarket options though?
Old Jul 25, 2009 | 04:04 PM
baron340's Avatar
Filling them with urethane works rather well, but be sure that the stock rubber is super clean before you start or the urethane will start to pull away from the stock rubber. It won't come out, it just looks like poo.
Old Jul 26, 2009 | 05:04 AM
85_305's Avatar
But i need to get all new motor mounts all the way around.. not ONLY the front one
Old Jul 26, 2009 | 06:45 AM
97el's Avatar
Beat me to it.
However, be aware that this option will lead to increased vibration at idle, as well as extra stress on the other mounts unless you fill them as well.
Old Jul 26, 2009 | 08:07 AM
85_305's Avatar
I'm not looking for all kinds of vibration and ****.. i'm enjoying this car stock and quiet. What do I do about the other mounts though?
Old Jul 26, 2009 | 01:21 PM
baron340's Avatar
Your options are this 1. replace them totally with new mounts. 2. fill them all with urethane. It will vibrate a tiny bit more but not too bad.
Old Jul 26, 2009 | 03:17 PM
85_305's Avatar
But what I'm asking is, where can I get new aftermarket mounts for it?
Old Jul 26, 2009 | 03:29 PM
Maple50175's Avatar
for the front mount what is the best way to replace it?
Old Jul 26, 2009 | 06:09 PM
baron340's Avatar
The only aftermarket mounts I know of are from passwordjdm, but they are like $300 and solid urethane. The solid urethane will be even stiffer than stock ones filled with window weld and will vibrate even more. Other than that you are stuck finding and oem replacement, which you can find at any auto parts store.
Old Jul 26, 2009 | 06:13 PM
85_305's Avatar
Damn. The hell with 300$. Looks like I'm getting new oem ones.
Old Jul 26, 2009 | 08:28 PM
toyomatt84's Avatar
Sanji
Be prepared to spend over $50 for them.
Old Jul 27, 2009 | 03:34 AM
85_305's Avatar
each???
Old Jul 28, 2009 | 05:31 AM
2001ex's Avatar
i was havin the same issues before i re-uped the stock mounts cost about the same as the aftermarket ones, but autozone sells them all sepratly so i reccomend inspecting all four of them and replace the ones that are jacked up. i would also invest in an ingalls tourqe dampner.
Old Jul 28, 2009 | 08:26 AM
85_305's Avatar
whats a torque dampner?
Old Jul 28, 2009 | 12:10 PM
2001ex's Avatar
its like a shock that goes between your motor and strut tower. it helps with wheel hop and hard shaking in 1st and 2nd gear. itll take some of the load off your motor mounts.
http://www.ingallseng.com/93026-stif...nda-civic.html
Old Jul 28, 2009 | 02:14 PM
85_305's Avatar
thats pretty damn cool.. thanks for the info
bunske123
Oct 10, 2007 10:50 PM
DeeCeeTwo
Jul 19, 2005 11:32 PM
Thundersquid
Oct 23, 2003 10:43 PM
Ri5e
Dec 26, 2001 04:29 PM
