Hesitation/misfire/dying
Well this post is not about having a problem, its about a problem that i just solved, i've been having a bad hesitation issue for a long time and recently it has gotten so bad that it starting misfiring in vtec, vtec would kick in but would pop and sputter to redline, this problem was casuing me so much stress that i just poured money non stop into it, i did countless hours of searching online and came up with nothing. the car also did not throw any codes even tho i would push it hard while misfiring to get a code to come up. the parts i had replaced were oe cap and rotor, ignitor, coil, plugs, wires, fuel filter, both O2 sensors, replaced ground wires, after all that and problem was still there, i then replaced the whole distributor and BAM problem went away, i was in so much relief it was unbelievable, the shitty thing is that i had just put a bunch of money into my old dizzy, ppl out there with hesitation/misfire problems that have replaced cap and rotor, coil and ignitor and still having issues need to swap the whole dizzy with a friend and try
fubar1217
Apr 10, 2006 07:56 AM
