B SERIES TURBO STUFF FOR SALE: AEM AND MORE..LOW BALLERS WELCOME
Contact info: larrysama@gmmail.com is best for faster response or PM me here
EVERYTHING IS OBO.
I will start out by saying I am not selling this stuff cause there is anything wrong with it, but only cause I am going to a Full Race set-up. Everything is in excellent condition and good working order. I made 486 at the wheels on 24lbs of boost on this set-up and have dyno sheets to back those numbers.
TAKING ALL REASONABLE OFFERS. everything is plus shipping unless we work out something on the price.
Turbo set-up is as follows:
-Garrett .60 trim turbo WITH 63ar- no shaft play 500.00
-Blox manifold (has a hair line crack. never had an issue with it) Jet Hot Coated-150.00
-Tial 38mm wastegate (10lb spring)-175.00
-45 degree wastgate elbow(Jet hot coated)- reasonable offer
-Custom dump tube (run away from engine bay to keep heat away) Jet Hot Coated-125.00
-Full 3” down pipe with 4 bolt flange(Jet Hot Coated)- 150.00
The others:
-Percision Intercooler - 300.00
-AEBS intake manifold with 68mm TB(off b16)- 350.00
-Nology wires- 100.00
-Greddy type "s" blow off valve- 100.00
-In-line pro blow off valve-100.00
AEM EMS(model 30-1010)-600.00
IF YOU NEED TO SEE SELLER FEED BACK I AM A MEMBER OF SRTFORUMS.COM AND MY SN IS SRT4STREET....I HAD MADE OVER 30 SUCCESSFUL TRANSACTIONS ON THERE.
Pics available upon request!
EVERYTHING IS OBO.
The others:
HickamHatch
Sep 19, 2012 04:27 AM
