B16B ECU
Old Jul 23, 2009 | 01:10 PM
SwissChEz82's Avatar
Default B16B ECU
I am trying to figure if there is a way to pass SMOG with a B16B. I have read of people at least in the recent past being able to get away with running a USDM P2T from a 99-00 Civic Si and being able to clear SMOG. Does anyone have any input or past experiences.
Thanks
Old Jul 23, 2009 | 01:31 PM
ek-g6's Avatar
Default Re: B16B ECU
I'm not sure how the smog stations are in oceanside, but over here, they tend to be lazy and not check the stamp of the motor. I'm sure witha good cat converter and the si ecu, you should be fine.
Old Jul 23, 2009 | 01:33 PM
wakaranai's Avatar
What car is the swap in?
I think the bigger concern is wether it will fail the visual for not being BAR'd and/or being a JDM motor, but that depends on the smog tech. If you can get passed that, I don't see an issue with emmissions as long as you have a cat.
Old Jul 24, 2009 | 09:18 AM
So you're telling me there's a chance. I wonder if it would be any easier on base? I guess we shall find out. Thanks for the information though. If anyone else has any experiences with this feel free to give feedback.
Old Jul 24, 2009 | 09:54 AM
Also with running the P2T what would be the difference between the OBD2a and OBD2b, is there any difference in the wiring or sensors?
acuteviet
Sep 10, 2006 01:59 PM
17
Jul 30, 2006 09:09 PM
SuperDuude
Oct 26, 2004 11:26 PM
ProudtobeANoob
Mar 7, 2003 02:53 PM
brad.
13
Aug 8, 2001 01:22 AM
