Suspension & Brakes Theory, alignment, spring rates....
Replacing Beaks SRK with ASR brace
Old Jul 23, 2009 | 11:52 AM
TrackSol's Avatar
Default Replacing Beaks SRK with ASR brace
Hey all. I've been running the Beaks SRK with my Mugen 26mm stabilizer bar along with TEIN FLEX 9k/4k coilovers for a while now with no problems, however I'm thinking about getting the ASR subframe brace.
When installing the Beaks SRK, you have to remove the welded on nuts on the inside of the subframe to install the back plates. I noticed that the ASR back plates go over the nuts and you drill the threads out of the OEM nuts.
Has anyone installed an ASR brace after having the Beaks SRK before? Could I just reuse the Beaks back plates? Or should I replace the entire subframe?
MILANO_RED_CL9
Acura TSX
Mar 24, 2011 07:43 AM
NobodyKnew
Nov 20, 2007 05:06 AM
mrdeadman
Feb 11, 2006 04:53 PM
dt4life
Suspension & Brakes
Feb 28, 2005 08:13 AM
