SOCAL FT/FS Clean title 1990 240sx Rebuilt KADE $4000
Clean Title 1990 240sx KA24DE FULL PERFORMANCE REBUILD ($4000 OBO) FS/FT Trade for equal value CAR (interested in only HATCHBACK), MOTORCYCLE.
Hi guys, need money to pay through my schooling so i can start fixing peoples back problems
. So my lose is another persons gain. So let this go by. This is completely rebuilt and ready to be pushed.
Original 5- Speed
NO A/C
Has Power Steering
No Accidents
Roll Down window
No Sunroof
Un-cracked Dash
Engine: 1996 KA24DE 240sx (Had 80k before rebuild) Right Now Literally Has only less than 2k Miles still in the break in process. Comes with fresh oil change.
- All New Fluids
- New Spark plug gasket
- All Gaskets OEM from Nissan dealer (have proof)
- Most of Parts are OEM Nissan dealer (have proof)
- Cometic Head Gasket
- New AMS timing chain with New guides
Bottom: Cleaned and All Balanced. (Have Proof of all purchase)
- Balanced crank with clutch and flywheel
- Supertech Pistons: .020 bored. (Dome shaped: for more boost)
- Eagle Rods
- Clevite 77 Rod and Main bearing.
- Crank was cleaned
- New Oil pump with New Front cover.
- New Water Pump
- New Nismo thermostat
- New Coolant temp sensor
Top: Cleaned and port and polished (also have Proof)
- Professionally Decked Head.
- 3 angle valve job
- Supertech Exhaust and Intake valve stem
- BC Springs/Retainer Double coiled.
- New valve guides
- S13 Camshaft
- All port and polished
- ARP head and Main bolts
Suspension:
- upgraded Tension Rods
- upgraded RUCA
- upgraded Rear traction Rod
- Upgraded Rear Toe arm
- Stock spring and shock.
Exterior:
Nothing everything is clean stock.
Interior:
Also completely stock
- Apexi turbo timer
- Nismo Shift ****
Engine Bay:
- New NGK Spark plug
- New NGK Spark plug wire
- Nology Coil
- AEM Short Ram intake
- SOLID MOTOR MOUNTS
- All New belts
- KOYO radiator
- DOHC power steering lines
- New 4-2-1 Exhaust Header
- Totally converted to OBD 1
Transmission:
- Stock.
- New clutch Bearing
- ACT Heavy duty pressure plate (Balanced)
- 6 Puck clutch
- New Throwout Bearing
- Fidanza Flywheel (Balanced)
- NISMO Clutch Slave
- New SS clutch Line
Other:
- New Knock senor with new plug, O2 as well
- New hoses
- Upgraded to Walbro Fuel pump
- New rebuilt Rack and pinion
- New rack and pinion bushing
Now for the bad:
- Crack on front windshield that was fixed.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
More:
Car for sale pictures by solomonanfree - Photobucket
. So my lose is another persons gain. So let this go by. This is completely rebuilt and ready to be pushed. Original 5- Speed
NO A/C
Has Power Steering
No Accidents
Roll Down window
No Sunroof
Un-cracked Dash
- All New Fluids
- Eagle Rods
- Crank was cleaned
- New Water Pump
- 3 angle valve job
- New valve guides
- S13 Camshaft
Suspension:
- upgraded RUCA
Exterior:
Interior:
- Apexi turbo timer
- Nismo Shift ****
Engine Bay:
- Nology Coil
- All New belts
- KOYO radiator
Transmission:
- Stock.
- 6 Puck clutch
Other:
- New hoses
Now for the bad:
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]More:
solomonanfree
Aug 6, 2009 10:07 PM
92tealTSI
Oct 28, 2003 06:54 AM
