what dizzy do you guys recommend for the obd0 to obd1 swap?
what are all the year and model civic's could i use?
so far i heard that a civic 92 DX works but the dizzy is clocked really off when its installed. so i am now curious which other make and models would work?
this is for a D16A6 ecu P28 obd1 swaped from the obd0.
thanks.
thanks.
Alll of the d-series 5th gen (92~95) trims are OBD1 and will work.
The Si (D16Z6 motor) will require mods to make it bolt on correctly.
(96~?) D16Y8 OBD2 distributor will bolt right up to your A6 and it is compatible with OBD1.
does it mean anything when the new dizzy needs to be fully advanced just to keept it at the correct degree?
CRXguy_88
Jul 2, 2010 04:30 PM
VegasInvasion
Jul 1, 2010 10:49 AM
DOHClessEF-9
12
Apr 21, 2005 06:07 PM
