Will trim paint be any good?
I was wondering if i buy some duplicolor trim paint to paint my front lip (urethane) will it stick onto the urethane? and will it also crack if the lip flexes a little?
noob question yes i know
also should i do any prep before painting or just spray right on?
from when i've used trim paint, it seems to be a little flexible...not sure if you can fully flex it, but i know it can move a little...as far as spraying the lip with it, are you going for like a matte look? cuz that's how it's going to look with trim paint...if you do want to paint with trim paint, i would at least sand the lip with some 600 to help the paint adhere then giving it a few light coats so it looks even throughout...try to spray a little then shake the can, spray a little more shake the can that way you have constant pressure and it wont look blotchy
Hello, I painted my Si lip with primer and flat black trim paint and it came out looking very OEM and I flexed the lip and the paint didn't crack at all. No clearcoat as it would not look OEM and I didnt sand it because I didn't have the right sized sandpaper for it and I needed the ones I had for something else and I didnt really care about it that much to have it be flawless. Besides the scratches that I didnt bother sanding, The paint itself came out excelent.
This is what I used:
From this:
To this:
From this:
To this:
alfaaay
Oct 20, 2003 07:12 PM
N0E5cape
Apr 8, 2002 09:54 AM
