92 Accord Engine revving
Old Jul 23, 2009 | 07:06 AM
rharm's Avatar
New User
Default 92 Accord Engine revving
I have a 92 accord that will rev from 1000 rpm to 2000 rpm and back down to 1000 rpm when at an idle. Could this be related to the timing belt or possibly a sensor?
Old Jul 23, 2009 | 07:12 AM
kirbyno1's Avatar
Default Re: 92 Accord Engine revving
Is it when its cold, warmed up, or both?
Old Jul 23, 2009 | 07:19 AM
rharm's Avatar
New User
Both
Old Jul 24, 2009 | 11:06 AM
jhondayang's Avatar
look at your fast idle valve and see if it's fully unscrewed out...
Old Jul 24, 2009 | 02:06 PM
hon2984's Avatar
FAQ forum: cleaning IACV, FITV
I'm sure it is probably your FITV.
It is located on the driverside of the intake manifold, with two phillips head screws on top, remove them, and tighten up the valve, you will need a very wide flat head screw driver. A gasket sraper works pretty well.
Old Jul 24, 2009 | 10:12 PM
Bwill9886's Avatar
If it is neither the IACV or FITV, also remember to check the TPS.
Meraut
Feb 6, 2013 07:52 PM
Ed ke6bnl
Aug 7, 2009 03:44 AM
gmrnguyen
May 4, 2009 09:51 AM
k-ozz
Dec 25, 2008 08:58 PM
stevescivic
Jan 12, 2007 08:51 PM
