B&M fuel pressure gauge install...
Old Jul 22, 2009 | 08:56 PM
jhammond_82's Avatar
Reject Papi
Default B&M fuel pressure gauge install...
Didn't see anything in the faq on this, so I figured i'd post it up, might make it in there. The gauge cost me roughly $42, and took aproximately 10 mins to install. Enjoy!
First things first. Relieve some of the pressure in the fuel system. This did help.
The tools you will need for this are: 17mm socket/ratchet, 12mm wrench, 17mm wrench, and some teflon tape.
Then, begin by taking off the banjo bolt with the socket. (its the one on the passenger side) Be careful of the fuel leaking out, use a rag to catch the excess.
Here's what it should look like when you take it out.
Next, use some teflon tape on the gauge threads to help make the seal. Then, insert the NEW banjo bolt, and NEW washer through the fuel fitting on the car. But, be sure not to lose the old crush washers, you will need to reuse one of them. Install the old washer under the fuel line on top of the filter itself.
Next, spin the gauge onto the new banjo bolt, using a copper washer as a seal also. Tighten the gauge till it is tight, not till it breaks. You can then adjust the angle that the gauge sits to read it properly.
Old Jul 22, 2009 | 09:06 PM
Circusraven's Avatar
Default Re: B&M fuel pressure gauge install...
I like it! I got me one of them there B&M's.
Southern California
Nov 26, 2010 05:21 AM
Ej8_KiD
Engine Management and Tuning
Oct 30, 2009 06:31 PM
ek-g6
Nov 15, 2007 10:29 PM
danteisme
May 29, 2005 04:29 PM
mike2016
Jul 3, 2001 01:01 PM
