hood wont open
Old Jul 22, 2009 | 08:48 PM
AznJdmKid's Avatar
Default hood wont open
i just finished my b18 swap in my 91 civic si, and bolted my hood back on and closed the hood. Then when i went to pull the latch inside the car, it felt like it was already open. So i went to try to pull the lever from under the hood, but i couldnt get to it. The hood is stuck and i think it's hittin the motor. Is there a way to get the hood open. Im in need of help.
Old Jul 22, 2009 | 09:02 PM
LightWeightED8's Avatar
Default Re: hood wont open
Depending on how much room you have between your front bumper and the front bulkhead. You can try to use a long screwdriver to release the latch.
Old Jul 22, 2009 | 09:40 PM
grog's Avatar
I've had that happen before, I just pushed and wiggled it until it freed up. Then i adjusted the latch. good luck
Old Jul 22, 2009 | 09:55 PM
Mr. DeOro's Avatar
have someone try to open the hood while you pull the latch... thats what I have to do to mine
Old Jul 22, 2009 | 11:00 PM
hisnibs's Avatar
You may also need to pull the release lever out all the way, then slip a finger in behind and pull on the cable some more.
If you have decently long arms, you should be able to do this while lifting the hood.
Old Jul 23, 2009 | 03:26 AM
.Manny.'s Avatar
Touching My Member
if all else fails...take the front bumper off to ease your troubles
Old Jul 23, 2009 | 12:16 PM
richboi's Avatar
x2...But also try pounding down on the hood where the latch is at while your buddy pulls the inside latch.
Old Jul 23, 2009 | 12:29 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Page from the manual:
An X-ray view of the mechanism:
BlitzSix
Jul 16, 2018 05:22 AM
julianbc2
May 22, 2010 01:16 PM
dohc_profile
Jan 30, 2007 03:59 PM
alupso
Mar 7, 2006 09:21 AM
