HELP! CEL code 22, 92 lx w/ z6
Old Jul 22, 2009 | 01:36 PM
92integraGSR's Avatar
Default HELP! CEL code 22, 92 lx w/ z6
car wont start, cel code is throwing 22(vtec pressure valve), two long pauses then two fast ones. car is a 92 lx with a d16z6 out of a 95 ex
main relay has been changed, cant get it figured out, pm or post with info, thanks!
Old Jul 22, 2009 | 02:13 PM
Former User's Avatar
Default Re: HELP! CEL code 22, 92 lx w/ z6
Ignore code 22 as it won't cause a no start.
Do you hear the fuel pump prime for 2 seconds when the key is turned to ON(II)??
Do you have bright white spark at the plugs?
When you look into the oil fill hole while the engine is cranking, do you see the rocker arms moving?
luckystryx
Aug 29, 2018 06:15 PM
wannabboosted
Jul 7, 2010 06:12 AM
[713]
Oct 21, 2008 12:13 PM
mericbe
Aug 22, 2005 06:01 PM
