Turn off seat belt buzzar. I have harnesses.
Old Jul 22, 2009 | 11:12 AM
jpnolan's Avatar
Default Turn off seat belt buzzar. I have harnesses.
Ok can someone please help me the previous owner cut the plugs under the seat so I can't get to them unless I pull the carpet... not going to happen. Is there any fuse I can pull or anything I can do? please help I can't listen to it beep anymore!!! Thanks.
Old Jul 22, 2009 | 11:31 AM
sde780's Avatar
Default Re: Turn off seat belt buzzar. I have harnesses.
under center console, passenger side, theres a flat rectangular black lid you can pop off. unplug the bright green plug, it should be closest to the firewall. that did the trick in my sedan
Old Jul 22, 2009 | 11:41 AM
dcvt16's Avatar
if its a 90-91 hatchback, the cover under the rearveiw mirrior, take it off and unplug the plug there.
Old Jul 22, 2009 | 12:12 PM
Fo-Do Fanatic's Avatar
mine dont work anymore from when i pulled my seats out and unplugged the little plug under the seat and didn't plug it back in.
Old Jul 22, 2009 | 12:16 PM
jhammond_82's Avatar
Reject Papi
yeah, all i did was unplug mine from underneath the seat. if the plugs are cut, wouldn't that be the same as being unplugged? thats odd..
Old Jul 22, 2009 | 12:18 PM
That is odd. I wonder if his door closed sensors are shot on one or both doors. Thats the only other thing I can think of that'd be causing your beeping.
Old Jul 22, 2009 | 01:00 PM
sde780's Avatar
unplugging the sensor on the bottom of the seat just made the seatbelt thing ring all the time instead of when i had my door partially closed
Old Jul 22, 2009 | 01:23 PM
My_EFsedan's Avatar
i had mines cut but i got the harness and solder them color coated to the cut one. for some reason it still beeps. so i ripped the speaker out of that box and problem solved. no beeps and seat belt works.
Old Jul 22, 2009 | 03:20 PM
Reject Papi
lol, i guess thats one way to get it done huh! ^
Old Jul 22, 2009 | 03:35 PM
My_EFsedan's Avatar
works for me almost 3 years now!
Old Jul 22, 2009 | 03:45 PM
jpnolan's Avatar
Ok so what I just did was unplug it from the seatbelt flashing sign in the sealing.
Thanks for all the help.
Old Jul 22, 2009 | 08:31 PM
BiG ChOr!Zo's Avatar
x2...this is the same exact thing i did and it has worked great since 2007
Phoenix007EF
Feb 26, 2010 10:07 PM
EGed up from the seat up
Feb 4, 2010 10:06 AM
garyc17
Jun 4, 2009 06:20 AM
Mr_ET
Jul 31, 2005 08:16 PM
92LudeSI
Feb 28, 2003 09:31 AM
