Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
****AEM METHANOL INJECTION KIT SALE FREE SHIPPING****
Old Jul 22, 2009 | 06:53 AM
Central Florida Turbo's Avatar
Default ****AEM METHANOL INJECTION KIT SALE FREE SHIPPING****
Hello Guys Got in Stock and Ready to Ship AEM METHANOL INJECTION KITS with FREE SHIPPING!
The AEM Water / Methanol Injection Kit is universal by design and adapts to virtually any forced induction gas or diesel engine via multiple jets to suit your vehicle’s power requirements.
WHY YOU WANT ONE
AEM’s Water / Methanol Injection Kit reduces air inlet temperatures and exhaust-gas temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
WHY YOU WANT OURS
AEM’s Water / Methanol Injection Kit includes all the features necessary to do water/methanol injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, we include a one- or five-gallon tank with a fluid level sensor standard. Also, because we think engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost via a ground output if the system runs out of fluid or detects an error. With the AEM Water / Methanol Injection Kit, you get all the best features in one low priced kit.
HOW IT WORKS
Once installed, the Water / Methanol Injection Kit uses a boost-dependent, variable-flow progressive controller to determine the amount of water / methanol mixture (up to 50%) to feed into the inlet stream from the included one- or five-gallon reservoir. The controller commands a progressive 150-PSI pump that delivers the mixture, and flow adjustments at the inlet are made via three included jets designed to match most engine power requirements. The result is significant horsepower gains using pump gas—at about half the cost of Racing Fuel.
OTHER COOL STUFF
You don’t have to worry whether AEM has your application because the Water / Methanol Injection Kit is designed to be universal for practically any vehicle. It includes everything you need to adapt it to your steed. Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, a dash light to warn of low fluid level or error codes (including short circuits, battery voltage and more), and an additional output to either decrease ignition timing or boost if the system detects low fluid levels or a system error.
TERMINOLOGY EXPLAINED
By now you’ve most likely heard various terms in reference to water/methanol injection systems. Some refer to these systems as just water injection, methanol injection, and/or meth injection for short. In addition to those terms, these systems are often referred to as alcohol injection or water/alcohol injection. The bottom line is all of these terms are used to reference the same type of system.
What some may or may not know is that methanol is known as methyl alcohol. Methanol’s scientific name is where the “alcohol” variant name has come from. Essentially, alcohol and methanol is the same thing, however there are different types of alcohol.
Call Us For unbeatable Prices Gauranteed!!!
Prices to low to advertise!!!
Old Jul 22, 2009 | 11:20 AM
Default Re: ****AEM METHANOL INJECTION KIT SALE FREE SHIPPING****
Bump bump!
Old Jul 22, 2009 | 01:16 PM
Bump!
Old Jul 23, 2009 | 07:36 AM
Bump!
Old Jul 24, 2009 | 03:00 PM
Bump!
Old Mar 13, 2010 | 07:47 PM
2jzmx6's Avatar
TRIAL USER
how much for a kit?
miahjera04
Apr 7, 2016 08:38 PM
raene
May 17, 2014 06:14 AM
Sean18337
Jan 15, 2014 07:06 AM
boostedb20z
Aug 14, 2009 09:13 AM
