check engine light on. rejecting scanner
Old Jul 21, 2009 | 02:59 PM
littlered06's Avatar
Default check engine light on. rejecting scanner
my check engine light came on and my car is rejecting scanners..it is a 96 with a type r swap. the light is off when i start the car and after driving for a few min it pops on and the car wont cross over. this all started when my battery died the other day and i cant figure this out.
Old Jul 21, 2009 | 03:02 PM
kei1's Avatar
New User
Default Re: check engine light on. rejecting scanner
it might be an issue with the plug. make sure all the wires on the back of the OBD plug are in tight. the only other thing is the scanner might not be good. ive had that happen plenty of times in the shop i work at. autozone does a free scan, check there. also cover your bases, check al the fuses and make sure the aletrnator is charging the system. sometimes its the simple stuff that gets you.
Old Jul 21, 2009 | 03:58 PM
it rejected 4 diff scanners lol so idk what is going on. i'll check the wires and check some fuses. ive driven the car a bit after the new battery so i assume the alt is charging fine.
Old Jul 21, 2009 | 04:47 PM
zodiac_00's Avatar
do you have a test light? if you do check to see if you have power at the DLC with the key in the on position or the car started. if no power check the fuse that the DLC run off
Old Jul 21, 2009 | 05:33 PM
ok i'll check that first thing tomorrow. car is outside in the dark
Old Jul 21, 2009 | 07:06 PM
1ls/vtec's Avatar
you can use a paperclip and jump the plug under the passenger dash and count the light. the Haynes manual will tell u how to do it.
SLOWEF1990
Nov 21, 2018 05:25 PM
geomon
Feb 15, 2013 11:32 PM
sqwale
Mar 18, 2005 04:13 PM
redludevtec
Aug 15, 2004 04:00 PM
