1990 ACCORD Passenger seat belt.
Old Jul 21, 2009 | 02:25 PM
mtebaldi's Avatar
New User
Default 1990 ACCORD Passenger seat belt.
When passenger door is opened seat belt does not retract to open position. Honda Tech replaced the slide latch mechinism on life time warranty. The latch will move from open to closed if manually moved there. But stopped short of repair completion staing that Honda america said completion of fix was warranty. The tech said to try the SB chime warning module under passenger seat and the door light sw.. I replaced both problem not fixed same issue I don't understand this at all. Any other ideas. I am thinking a possible sw on the slide rail.
Old Jul 24, 2009 | 03:58 PM
mtebaldi's Avatar
New User
Default Re: 1990 ACCORD Passenger seat belt.
Well since there is no one on this forum that can answer or give advice to this question. I will answer it for my self and possibly stir some thinking.
Sympton: Seat belt does not move to forward or open door position. Since seatbelts are lifetime warranty went to honda. they replaced the slide latch which didnt fix the problem. From there they said Honda America said ok must be electrical problem not warranty anymore. Honda wanted $260.00 to diagnose the problem. Checked electrial connections with DVM, after 5hrs found out that the door latch assembly is in the circuit for door open/close. Door open latch moves to forward position. Door closed door moves to rear position. Wether door closed or open saw no change in slide position. Jumped out switch and slide moved to forward position. Problem identified, cost new 345.00 factory. Will check other source and call Honda and ask if they will cover with warranty. Hope this helps anyone else. I am not being insulting people I just thought there were honda technicians on this site that had answers.
ThePizzaMan
12
Jan 22, 2013 09:16 PM
Lasty K
Dec 8, 2008 11:29 PM
civicracer1600
May 5, 2007 05:22 PM
silverEH2
13
Mar 26, 2003 08:27 AM
