B16 AND B18C DIFFERENTIAL BEARING
There are a few differences. The B16 bearing is pretty straight forward 1 pc. bearing. The GSR/Type R differential bearing uses a Taper 2pc. style and is a bit taller as Bone mentioned...There is also a 1 pc. B18C bearing that came in the last few years of the Integra that is called an offset bearing that is also taller in the center. So there are a couple of them.
oldspriteguy
Apr 30, 2012 05:06 PM
accord, b16, b18, bearing, bearings, diff, differenial, differential, gsr, honda, odyssey, replacement, series, tech, transmission
