CRX Transmission Problems
Old Jul 21, 2009 | 12:27 PM
scottmog's Avatar
Default CRX Transmission Problems
Hey i got an auto crx 1990 and have two problems that is an often problem for a 20 tear old tranny.
1. hard jump feeling from 1st to 2nd and 2nd to 3rd when the car shifts
2. shuttering and studering when i am in reverse and hold the brake
what kind of liquid should i put in the tranny to help this out? or should i just change the tranny fluid first and see if the problems go away?
thank you
-scott
Old Jul 21, 2009 | 12:44 PM
sleepingciv's Avatar
Default Re: CRX Transmission Problems
change the fluid and filter
use Honda atf for best results
Old Jul 21, 2009 | 01:00 PM
scottmog's Avatar
There is a tranny filter? Never knew that. But yes I already bought some fluid from the dealer
Old Jul 21, 2009 | 01:02 PM
yup there is
http://www.google.com/products?hl=en...-8&sa=N&tab=if
Old Jul 21, 2009 | 01:17 PM
4drEF's Avatar
Keyboard Humorist
Sounds like you actually might be in gear by how your car shutters when you are in reverse with the brake on.
Try adjusting your shift cable.
Old Jul 21, 2009 | 01:43 PM
rustbucketrex's Avatar
If your transmission is an automatic, you will have a filter. A 5 speed manual does not. Use Honda MTF in a standard shift transmission.
Old Jul 21, 2009 | 03:37 PM
4drEF's Avatar
Keyboard Humorist
Originally Posted by rustbucketrex
If your transmission is an automatic...
"Hey i got an auto crx ..."
Easyslider01
Honda S2000
16
Mar 12, 2007 07:44 PM
KYLE.ECKERT
12
Aug 20, 2006 11:37 AM
Paprika
17
Jun 27, 2006 11:55 PM
00accordguy
Dec 9, 2005 05:09 AM
