Need to know
Old Jul 21, 2009 | 11:35 AM
madgeo's Avatar
Default Need to know
Im doin a B18b swap on a 90 HF. I need to know if i can use my stock throttle cable and clutch cable or will i need to get both from a 90-93 integra?
I could use both but there is no way to keep the throttle cable in its spot and the clutch cable can stay in the bracket.
Any help with this would be helpful and appreicated
Old Jul 21, 2009 | 11:46 AM
skidmarkroyalty's Avatar
Default Re: Need to know
well i bought6 an ls swapped hatch just for the swap to go into my crx si, and my stoc k si clutch cable and throttle cable didnt work, i had to take the cables from the hatch that the swap came out of, so i would say you need the ones from a da.
Old Jul 21, 2009 | 12:00 PM
EL Vap133's Avatar
I used a throttle and clutch cable from a DA and they worked fine.
Old Jul 21, 2009 | 02:49 PM
bradennicely's Avatar
Old Jul 22, 2009 | 10:45 AM
madgeo's Avatar
Should i get throttle and clutch cable from a DA?
A guy around here has been helping me and says that i could use both old cables.
All i have to do is make a bracket for the throttle and the clutch should fine???
The clutch cable tight and pulling up on the arm. the throttle is on but no where to fasten down to use right??? This swap is easy if you have all parts needed for it but
if you dont, its PITA.
Old Jul 22, 2009 | 11:50 AM
4drEF's Avatar
Keyboard Humorist
If your goal is to get this to function then the reply 2 posts up answered your question.
Maybe you just don't trust that El Vap133 guy?
Old Jul 22, 2009 | 11:53 AM
D16SiHatch's Avatar
i used my stock clutch cable and a da throttle cable. the da cable, although nearing the end of its range of adjustment, works just fine.
Old Jul 22, 2009 | 12:00 PM
EF9ZC's Avatar
I had to use a da clutch cable and throttle cable on my old car. b16a in a 91 crx si hasport mounts.
Old Jul 22, 2009 | 03:41 PM
black0hatch's Avatar
you definatly need the da throttle cable but you can use your stock clutch cable or a da one will work too.
rewerbcrx
Jan 17, 2006 09:56 AM
ironchef25
10
Jan 20, 2004 12:26 PM
S13 slide
Apr 11, 2002 08:42 AM
13secondcivic
Feb 17, 2002 06:38 PM
BoostinDC2
Feb 17, 2002 05:41 PM
