97 accord A/C problems
Old Jul 21, 2009 | 09:54 AM
RhdRicheeee's Avatar
Default 97 accord A/C problems
hi
97 accord
150k miles
When engaged the A/C was blowing cold air BUT would stop blowing air at all and than start again in 30 second intervals this has happened for the past couple months every once and awhile but the past week it has gotten more frequent
now the A/C does not blow any air at all not even from the defrost or heater when engaged
any suggestions
thank you
Old Jul 21, 2009 | 09:58 AM
fu627's Avatar
Default Re: 97 accord A/C problems
Does air blow when in a different setting like defrost or heat?
Old Jul 21, 2009 | 10:15 AM
no it does not
Old Jul 21, 2009 | 10:30 AM
fu627's Avatar
Sounds silly but pull the **** off and check to see if the **** is just spinning on the stub there. You can just grab ahold of the stub and turn it. Turn on something and turn the **** all the way to the left then all the way to the right. Should click or rachet like 4 times from off to the high speed. If now air blows then, then sounds like the blower motor is bad or check fuse or there may be a relay. If it does, you just need a new **** or some super glue. HA.
Old Jul 21, 2009 | 10:40 AM
I dont think its the **** because it was working and turning off and on once and awhile
and than it gave up
is there a way to check it or just replace it and see what happens?
Old Jul 21, 2009 | 11:00 AM
fu627's Avatar
Just about has to be blower motor related. Either mechanical or electrical since none of your functions blow any air at all. The a/c compressor normally cycles on and off itself but there should be no difference in what blows in the cabin of the car you know. I just thought maybe you turned the fan **** off and when you went to turn it on it wouldn't, then the **** could be a factor. That just happened to me last week.
Old Jul 21, 2009 | 11:03 AM
sorry when I meant it turned off and on I meant
the ac would blow cold air than stop for 30 secs than blow air than stop maybe every three days this would happen
Old Jul 21, 2009 | 11:06 AM
update the first post btw for more clarification
Old Jul 21, 2009 | 11:18 AM
fu627's Avatar
So now I am confused. Does or does it not blow air at any other setting now? I am assuming previously you did not know because it was only set on a/c.
Whoops I see you already answered that with the beginning post edit.
So I would be willing to bet the blower motor has either had a short or has been going out.
Old Jul 21, 2009 | 11:22 AM
RIGHT NOW
it does not blow any air at all cold / hot air
IT USED TO
work fine but would sometimes stop blowing for about 30 seconds and than work again and this would happen every once and awhile
thanks for all your help does that clear it up?
Atalbot20
Mar 31, 2018 09:32 AM
honda94accord
Aug 10, 2007 02:21 PM
rrkss
Sep 15, 2006 09:16 AM
aklbear
Apr 15, 2005 08:30 PM
fizzbob7
Aug 9, 2004 06:48 PM
