b16 sputters or stalls
Old Jul 21, 2009 | 08:13 AM
bl1tzk1213g's Avatar
Default b16 sputters or stalls
Ok here's what happened. I was going on a short uphill when I started losing power, I thought I was in the wrong gear. I thought I was in fourth so I pressed on the clutched and realized I was on right gear (2nd) then the car died on me. It cranked but it didn't start, I had to press on the gas then it would start and sputter a little before it regains normal idling. It happened twice to me that night.
Sometimes when overtaking, I would press on the gas and somewhere along the rpm I lose power, like it's not even pulling (sputters), even on VTEC sometimes
I had my oil changed and noticed oil was leaking to the plugs in one of the cylinders. So we changed the O-Rings on the plugs and I thought it was going to fix it. It didn't. Then I changed the plugs still didn't help. My mechanic was thinking of the coils or the distributor itself but I think it might have to do with fuel since I have to press on the gas for it to start after it stalls.
Fuel pump, Fuel filter, main relay?
99 Civic SiR with B16A
Old Jul 21, 2009 | 08:44 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: b16 sputters or stalls
fuel filters are cheap. switch that out if you havent lately
and get a new fuel pump walboro 255lph cheaper than stock.
your main relay should be fine. its either good or bad
Old Jul 21, 2009 | 08:46 AM
Former User's Avatar
Is the CEL ON?
I would not rule out the distributor at this point. In addition, when were the plug wires, cap, and rotor last replaced or inspected?
Old Jul 22, 2009 | 10:20 AM
Okay i'll get my fuel filter changed. Throwing no cells, and since I bought the car i haven't checked or replaced the wires cap and rotor.
Old Oct 2, 2009 | 05:11 AM
Ok i haven't changed the fuel filter because I saw my intake was clogged so i cleaned and it. It stopped stalling on me but I still bog on high RPMS, around 6.5 or 7 rpms. Could it be the fuel filter or plug wires?
battleREADYb20
May 18, 2009 11:02 AM
LSDA9Nick
Jan 26, 2008 11:13 PM
Riceburner247
Jan 5, 2006 04:57 PM
prendi
Aug 9, 2005 09:14 AM
RiceBoysDream
Jun 28, 2003 01:16 PM
