Long Pause Before Car Cranks
I need help figuring out way there is such a long pause before the car will crank. When i turn the key the car will not crank, I have to hold the key turned for about 3-5 seconds before the car turns over. But when it does finally crank it starts up fine. Any ideas?
hapends to me, ended up being a loose ground from my tranny to my chasis. i say put "check grounds" on you checklist. but before i figured out it was the ground i changed my starter and my main relay, so i would at least check your main grounds before changing yoru starter, including ur battery ground. good luck.
Aquila
20
Sep 28, 2016 05:59 PM
