eg ls/vtec over heat problem
got an ls/vtec swap in an eg coupe. recently got a bigger radiator and bled all the lines ocrrectly. when driving at low RPMs the needle doesnt move past about a 1/4 as soon as vtec pops the needle goes right to the top and stays for a bit then slowly makes it waty back down staying at 3/4...any ideas? thermostat maybe?
what Water pump are you running with your setting? I heard if you use and LS water pump with 19 Teeth, it spends to fast causing air bubbles and overheating issues. If you change to GSR/B16 with 22 teeth remember you have to change your timing belt to an GSR/B16 with more teeth then the LS.
the teeth wont make it spin faster on the water pump. it would be the size of the pulley being used. so if the overall diameter of the pulley is bigger or smaller then i could see it spinning faster or slower.
the water pump is completly submerged in coolant so i find it hard to beleive that you will be sucking in air bubbles do to spinning to fast. your cooling system is a sealed system so the only way you could bring in air bubbles is if you have a leak somewhere.
i could be very wrong on this but this seems logical.
if tempature is risng and falling and you JUST worked with the cooling system tehn the most common cause is an air bubble liek ron stated. start with bleeding the system and keep adding fluid whenever you can since your driving the car still. those air bubbles will work out eventually overtime but bleeding the system will work faster and safer for you.
heat is the enemy of motors so if your running "hot" your basically hurting your motor.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Scroll 1/4 down to the waterpump area.
