rear sway confusion...someone help
Old Aug 23, 2002 | 06:17 AM
tinkfist's Avatar
Default rear sway confusion...someone help
there have been a few posts recently about which rear sway bar and what mounting kit (if even necessary) can be put on which civic (generation or trim). if anyone out there has it straight, a listing would be much appreciated. i think a lot of people would benefit.
1998 civic ex coupe ... working on suspension
Old Aug 23, 2002 | 06:22 AM
tonyxcom's Avatar
Default Re: rear sway confusion...someone help (tinkfist)
here are your two best choices.
ITR bar with Beaks Reinforcement kit http://www.beaksproducts.com
Comptech Sway/Tie combo
You will get max performance and max subframe protection from both of the above.
Old Aug 23, 2002 | 06:52 AM
Spade's Avatar
Default Re: rear sway confusion...someone help (tonyxcom)
He can also use any of the 19mm rear bars without worry.
Suspension tech sells both a front bar and a rear bar for 230 dollars. Well you can get them through summitracing for that price.
The front is 25.5mm and the rear is 19mm.
fongph
Apr 15, 2005 10:18 AM
turbotime
Dec 26, 2004 11:39 AM
MikeyDB7
Jan 21, 2004 11:22 PM
KillerWabbit
24
Jan 7, 2004 04:31 AM
ej1civic
36
Jul 23, 2003 08:20 AM
