what is need for a JDM D15B longblock swap?
1) what parts do i need to do the swap and about how much?
- how much is the most shops will charge for an auto to manuel swap?
2) what is better, the d15 swap or gsr?
2) GSR swap is better, but could confuse the living **** out of a newb. Also if you are in SoCal and your car has a D-series in it now, good luck getting the ref to sign off on a B-series swap.
1) What car are you putting this in? Also, shop around, you will find D15B long blocks for $400-$500
I'd say your best bet swap wise if you are looking to get it reffed is a B16 from a 99-00 SI or 94+ Del Sol VTEC, USDM engine of course.
Good luck on this one, just do tons of research and maybe talk to your local ref before buying a swap.
