Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: Fuse Box Diagram
Important information to help you understand your Honda.
Fuse Box Diagram 94-97 accord
Not sure exacly what you are wanting......of course you could always register you car with Honda owners link and download the owners manual in a pdf that would have this information (www dot ahm-ownerlink dot com).
This is from a 94, should be the same.
Just bought a 97 honda accord was told the radio did not work. I took out the radio checked all the fuses everything worked I used a multimeter to test current everything was fine I pluged back the radio and jiggled the wires around...it came on for a few min then cut off. Then I went to check the fuses under the hood none of them make my light on my tester light up so I checked under the driver side fuses they no longer light up my tester.. The power windows and lock still work and when I test the wire for the radio it lights up my tester and the light on the radio stays on but now the turn Sinhals don't work along with the fues need help ASAP
I need to know what fuse controls the signal lights on the car. my signal lights inside the car or outside work but the hazard lights work and the high beams and head lights. is it the fuse?
starbux57
Jul 19, 2025 04:21 PM
