Rear main seal?!
I just looked up the part numbers for both the sohc and dohc and the rear main seals are under different part numbers.
DOHC Part Number:1094004
SOHC Part Number:18486
as soon as you take out the seal you risk damaging it. it might not be "noticiable" but you know that it is worn none the less.
rear main seal is a littel bit more time-consuming then any other seal on the car. i personally would hate to do it twice if need be.
91214-PLE-003
91214-PH1-013
91214-PH1-004
These are just different manufacturers of the rear main seal, but all three of these part numbers come up on a D16Z6 and B16A2 when I checked www.hondapartsdeals.com
Honda Part Numbers:
91214-PLE-003
91214-PH1-013
91214-PH1-004
91214-PLE-003
91214-PH1-013
91214-PH1-004
if it works....grats. if it doenst work...dam.. would hate to do it all over again with the purchase of two main seals then (one for each engine since both engines wont have seals)
this wouldnt be a problem BUT the job to remove the seal is a littel mroe time consuming then lets say...a vavle cover gasket.
Originally Posted by hondahead'
i will check the part number for the sohc seal when i get home and see if they match any that u gave me, its oem honda so i hope so thanks tho!
crxnj
Jan 31, 2006 03:33 PM
